Open Source Sofware
BobCAD-CAM Toolpath Comparison Matrix
Matrix Legend
·  Included
*  Optional
BobCAM for SOLIDWORKS™ Product Matrix
TOOLPATH
MATRIX
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
2.5 AXIS TOOLPATHS
Profiling & Pocketing
Engraving
Thread Milling
Plunge Roughing
Facing
Chamfering
Rest Machining
High Speed Pocketing
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
3 AXIS TOOLPATHS
3 Axis Wireframe
Planar
Spiral
3 Axis Engraving
Radial
3D Plunge Roughing
Z-Level Roughing
Z-Level Finishing
Advanced Z-Level Finish
Advanced Planar
Advanced Roughing
Flatlands
Equidistant Offset
Pencil
High Speed Roughing
Rest Machining
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
Surface Based Toolpaths (3, 4 & 5 AXIS OUTPUT)
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves
Parallel to Multiple Curves
Project Curves
Morph Between Surfaces
Parallel to Surface
Flowline
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
4 AXIS TOOLPATHS
Indexing
Wrapping
Rotary
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
5 AXIS TOOLPATHS
Trimming
Indexing
Swarf Machining
High Speed Multiaxis Roughing
Express
3 AXIS STD
3 AXIS PRO
4 AXIS STD
4 AXIS PRO
5 AXIS STD
5 AXIS PRO
DRILLING TOOLPATH
Center Drill
Drill
Chamfer Drill
Chamfer Mill
Ream
Bore
Tap
Rolling Tap
Counterbore Drill
Counterbore Mill
Lathe Module
TURNING TOOLPATH
OD/ID Roughing
OD/ID Finishing
OD/ID Grooving
Drilling
Threading
Cut Off With Chamfer & Fillet Corner Break Options
Stock Feed
Pattern Repeat Cycles
Auto-Assignment of Finish Passes
