Posted March 8, 2017 3:42 pm   Published by    BobCAD-CAM
CAM (Computer Aided Machining) software is the modern solution to reaching higher levels of efficiency in CNC machining automation. Can your shop benefit from CAM technology? More often than ever before machine shops are using multiple CNC programming systems most likely because they need options and no CAM software does everything. The reasons are simple. Some CAM products require large budgets and others just don’t offer enough. BobCAD-CAM is unique due to the volume of functionality. Not many CAD-CAM products do it all and small to mid-sized machine shops can benefit from having a primary system with a supporting cast of programming solutions in order to meet all of their programming needs. How can BobCAD-CAM fit the bill as your primary CAD-CAM solution?
3d-cad-cam-finishing-toolpath Benefiting From BobCAD-CAM CNC Programming Software is Easy
BobCAD-CAM software has been inside of machine shops for more than 30 years as a solution to automating the part making process for CNC machining. CAD data is needed in order to program toolpath. In today’s manufacturing engineering solid models are primarily used. BobCAD-CAM provides CAD importing as well as full solid modeling functionality so that manufacturers can either import their part models for programming or design them from scratch. This allows shops to easily access CAD parts or make them easier inside of BobCAD-CAM. CAD Design features include drawing with wireframes, surfaces and solids.
3-axis-rest-finishing-cad-cam-cnc-simulation-milling22D & 3D Machine Toolpaths for CNC Programming
BobCAD-CAM is a modular system. The modular advantage to CAM software is that you do not have top pay money for features you simply do not need. Instead, you get to grow with the software. The software can be used for Hole Drilling, 2.5, 3, 4 & 5 axis. Adding machining functionality is easy and affordable. Profiling, pocketing, 3D Semi-Finishing, 3D Finishing and special REST machining toolpaths machining operations with a host of customizable features make machining simple while using the Wizards. Wizards step the operator through the process of programming while removing the guesswork from the entire process. Dynamic Machining Strategies® allow you to use multiple machining strategies for a single CAD feature on a model. This streamlines the setup process by automatically adding the appropriate fields to the Wizard and making sure nothing is missed. This also cuts down overall programming time. Dynamic Machining Strategies™ take the wizard concept even further by allowing the operator to load and setup multiple machining operations in one wizard rather than having to individually load them into the CAM Tree for separate steps. The software is there to make the process easier. DMS streamlines programming and reduces the overall amount of actual clicks that have to take place to get a job programmed for the machine tool controller.
HAAS-VF-3-pocket-simulationCAM Software Machine Simulation & Post Processing
BobCAD-CAM adds the benefit of simulation and customizable machine post processing. Simulation gives you the ability to visualize machining to inspect and eliminate potential mistakes. The Machine Simulation Pro module allows you to use your machine kinematics to simulate the process with the machine you have. This is highly beneficial. When it comes to posting the software can post out to Milling, Lathe, Router, Water Jet, Laser, Burning and Plasma CNC machines. This means that essentially, you only need one BobCAD-CAM for multiple CNC machines on your shop floor. This can not only save money but it can speed up productivity as well.
With so many productivity enhancing benefits, the BobCAD-CAM software is a great product to implement into your CNC manufacturing process.
Download a Free Trial today! Click HERE
Here are Other articles that you might be interested in:
7-steps-to-better-cad-cam-software-productivity top-10-cad-cam-advantages-for-cnc-machining
rssyoutube
