Open Source Sofware
4th Axis rotary Tool-path puzzle.
Home New Forums BobCAD-CAM Forums 4th Axis rotary Tool-path puzzle.
This topic contains 20 replies, has 4 voices, and was last updated by  Donald 2 years, 4 months ago.
Viewing 6 posts - 16 through 21 (of 21 total)
  • Author
    Posts
  • #15638
    Nick
    Participant
    Calum,
    A very kind chap on cnczone helped out on the issue of rotary cuts below the rotary axis.
    Although the somewhat cryptic Help entry gives no hint of this it’s the Base Point which needs to be set to define an axis within the part, paths can then be generated down to this Base Point. (Base Point isn’t even a point, it’s an alternate axis for the part parallel to the defined rotary axis.)
    If your rotary axis is in X then use Y and Z to define an alternate axis parallel to the rotary axis and use this to generate paths for the problem section.
    Parts with multiple sections where one axis will not suffice can be processed as several sections, each with it’s own appropriately set Base Point (It’s not a point it’s an axis).
    For my S shaped part I needed 3 Base Points with the job split into sections along the axis, see image attached
    Best Regards,
    Nick
    You must be logged in to view attached files.
    #15656
    calum
    Participant
    Thanks Nick that sorted things out. I have been following this on CNCzone too.
    The help is a bit vague on these base lines.
    Calum
    #15657
    RAF
    Participant
    Calum
    Are you able to get roughing passes with as much surface height differences that you have?
    I’m having trouble with differences of approx. .75 inch it will give me large rapids in to part to lower surfaces maybe you won’t get them if don’t have sharp drops.
    RAF
    #15661
    calum
    Participant
    I’m not sure what you are getting at. What I have done is use multiple 4th axis rotary features with decreasing allowance, 20mm down to 1mm, then do a finish pass. I did this because the Multiple Passes option of the 4 axis rotary feature didn’t give the results I expected, might now that I understand the base line better. Is there another way to do roughing? Guess I could use 3d features and indexing, still have a lot to learn.
    Calum
    #15677
    Nick
    Participant
    Help entries describe parameters from poorly to entirely inadequately, it’s no wonder we’re struggling.
    #20752
    Donald
    Participant
    I made similar stuff and use the spinning tool that I was able to fix and add more functions on it. Also added lever to work up and down.
    Regards.
    Donald
    “game designer at http://www.igamesforgirls.com/adventure
You must be logged in to reply to this topic.
