Tech Tuesday: Mill 3 Axis Standard vs Mill 3 Axis Professional CAD-CAM Software
Posted February 6, 2018 5:18 pm   Published by    BobCAD-CAM ">
Why Upgrade to Mill Professional?
Let’s take a look at the similarities and differences between these 2 powerful CAD-CAM packages and why many users choose to upgrade to our Professional Level of 3D Milling CAD-CAM Software.
CAD Features
BobCAD’s unique modular CAM software includes all of our CAD features with every “level” of the 3 Axis Milling software. User’s do not need to buy “solids” or file extensions for popular CAD packages. BobCAD’s CAD software is a complete wireframe, surface and solid modeler that includes a history tree to keep track of Solid Design steps and modifications. Industry standard file translators come standard. This is important to note due to so many CAD & CAM packages charging extra for what we include as a standard.
Upgrading to Mill Professional for 3 Axis Milling, CAD features is not one of the reasons.
Toolpath Operations
Let’s face it, 3D machining comes down to the Toolpath operations you have access to. Programming efficiently and precisely ultimately comes down to what Toolpath options you do or do not have.
BobCAD CAM 3 Axis Mill Standard Toolpath Operations:
BobCAD CAM 3 Axis Mill Professional Toolpath Operations:
If you were basing your decision to upgrade based on the number of Toolpath options you’ll have access to, then upgrading to Mill Professional is an easy choice. However, it’s not just about having more options, it’s also about what those options provide you. Not everyone needs all the advanced 3D machining options the BobCAD CAM Mill Professional provides. There are many go-to features for 3D Milling that BobCAD’s 3 Axis Mill Professional has to offer, Next, let’s take a look at the roughing options for users that distinguishes Standard users from Professional users.
Key Features of 3D  Roughing
Tool Entry-
How your tool gets into the material is extremely important. Often, tool entry plays a huge role in runtime. Mill Professional offers more tool entry options, but the one I want you to put your attention on is the Non-Center cutting option. This allows users to force tool entry from the side of the material versus plunging.
Mill Standard Mill Professional
Plunge (With Peck Options) Non-Center Cutting
Ramp Plunge (with Peck Options)
Spiral Ramp Automatic
Ramp Line
 Ramp Spiral
 Ramp Zig Zag
 Ramp Profile
Tip: Ramp Automatic switches entry styles as needed to optimize Tool Entry.
Boundary Options-
A boundary is used to “contain” Toolpath in a specific area. Users select a wireframe chain or surface edges to define an area to keep the tool in.
Center of Tool Center of Tool
Tool Inside
Tool Outside
Tip: More options equals more control with less design work.
Toolpath Patterns/Options-
Toolpath patterns affect the direction or “flow” of your Toolpath. Depending on the hardness of the material you are working with, your machine setup and complexity of your job having options become critical to precision success. These patterns and options affect run time, surface finish, stock remaining and more.
Offset In/Out Offset In/Out
Parallel
Adaptive
Intermedial Steps
Rest Roughing
Smoothing
When it comes to roughing, users have more options that aid in machining all kinds of materials, setups.
Gouge Checking With Check Surfaces-
This Toolpath containment feature really changes the game when containing Toolpath. Unlike a boundary, check surfaces provides the user more control over what happens when a tool (or tool assembly) makes contact with user-selected “check surfaces”.
N/A Gouge Check
Retract Tool
Trim Relink
v31 cam software download
Let’s take a look what’s the same and what’s different between these 2 powerful CAD-CAM packages and why many users choose to upgrade to our Professional Level or 3D Milling CAD-CAM Software.
