Give Your CNC Milling Productivity a Boost with the New BobCAD-CAM
The increased programming automation and smarter toolsets equals fewer clicks and a more efficient use of your time.
It's the most user-friendly CAD-CAM software available - which means you spend less time guessing and more time machining.
See how you can Easily Program Your 2D & 3D Parts!
Our Live One-On-One CAD-CAM Demonstration allow us to match you with a CAD-CAM Technical Advisor for a customized online meeting where you’ll receive a guided tour of the software. Tell us the type of jobs and parts you work on and we’ll show you the tools you can use to design and program your parts faster, easier, and more efficiently. Sign Up Today!
BobCAD-CAM milling software delivers the functionality you need to complete everything from simple 2.5 axis cutting to complex 4 & 5 axis simultaneous milling. It incorporates a full range of sophisticated and fully associative machining strategies through a simple wizard driven interface to make programming quicker and easier, even for new and occasional users. Dynamic Machining Strategies™ minimize your programming time by allowing you to assign multiple machining strategies to a single feature while advanced simulation functionality lets you test and confirm your work to give you the peace of mind in your CNC programming.
Features of BobCAD-CAM for CNC Mill
Powerful & Standard File Translators
BobCAD-CAM software is compatible with a large variety of file formats to give you the flexibility needed when working with client files. (DXF, DWG, IGES, STEP, SAT, 3DM, X_T, X_B, SLDPRT, STL)
Post Processor Library
BobCAD-CAM offers a large library of downloadable post processors that work with variety of machine types from many of the biggest machine manufacturers in the industry. Customize the post to fit your specific machine requirements or BobCAD-CAM can customize a post for you.
Advanced 2, 3, 4, & 5 Axis Toolpaths
The BobCAD-CAM milling software offers a wide variety of powerful toolpath strategies to give you advanced control over how you target your part. Take full advantage of your CNC milling machine with adaptive high speed toolpaths, 4 & 5 axis simultaneous machining, and other advanced milling capabilities.
Solid Simulation with Machine Components
Utilize your machine’s configuration and kinematics to test and confirm your mill programming before ever cutting a chip. Use it to view the complete milling process, detect machined part deviations and collisions, calculate cycle times, and more!
Multiple Jobs & Multiple Setups
BobCAD-CAM’s comprehensive milling solution allows you to program multiple machining centers and multiple part setups for a single job in the CAM tree. Easily create multiple setups in any part origin using BobCAD-CAM’s dynamic part origin to define the X, Y, and Z of your part.
Program From Wire Frame, Surface Edges, Surfaces, or Solids
Toolpaths in BobCAD-CAM support wireframe boundaries, surface edge loops, and constant Z profile to allow you to work directly off surface and solid models. The ability to define hole depths and pockets directly off selected surfaces provide enhanced control for shops working with wireframe drawings or surfaces and solids.
