SAVE ON A CUSTOM CAD-CAM BUNDLE::BUILD IT TODAY!
Speak to a CAD-CAM Specialist at
866-535-3744
877-262-2231
Customer Success
Education
Partner Program
Search
Toggle navigation
Free Demo
Products
SOFTWARE MODULES
Probing
CAD Design
Mill
Lathe
Mill Turn
Laser, Plasma & WaterJet
Wire EDM
Router
Art
NC Editor
Machine Simulation
TOOLPATH OPTIONS
Matrix
3x Mill Premium
BobCAD-CAM
NEW RELEASE
What's New in V38
Version Comparison
BobCAM for SOLIDWORKS™
What's New in V13
Videos
BobCAD V38 Getting Started
BobCAM for SolidWorks V13 Getting Started
BobCAD After Dark
Customer Success
Trade Shows
Made With BobCAD
News
Support
Advantage Plans
Support Site
Contact
Store
Advantage
Customer Success
Education
Give Your CNC Milling Productivity a Boost with the New BobCAD-CAM
The increased programming automation and smarter toolsets equals fewer clicks and a more efficient use of your time.
It's the most user-friendly CAD-CAM software available - which means you spend less time guessing and more time machining.
See how you can Easily Program Your 2D & 3D Parts!
Our
Live One-On-One CAD-CAM Demonstration
allow us to match you with a CAD-CAM Technical Advisor for a customized online meeting where you’ll receive a guided tour of the software. Tell us the type of jobs and parts you work on and we’ll show you the tools you can use to design and program your parts faster, easier, and more efficiently.
Sign Up Today!
TRY IT FREE
Our
Sign Up Today!
Try It Free
What is your industry?
Aftermarket Automotive
Blow Mold - Glass
Blow Mold - Plastic
Casting Equipment
Ceramics Manufacture
Composite manufacture
Composite Tooling
Dental Implants
Dental Reconstruction
Education
Embossing Dies
Firearms
Footwear - Orthopedic
Footwear - Sports
Forge Toolmaking
General CNC Machining
Impellers
Inspection
Jewelry Design
Jewelry Manufacturing
NC Programming
Oil & Gas
Other
Other Toolmaking
Pattern Making
Plastic Molds
Product Design & Manufacture
Production Machining
Project Management
Prototype Model Making
Pumps
Do you already use CAD software?
BobCAD
SOLIDWORKS
AutoCAD
Autodesk Inventor
TurboCAD
RhinoCAD
Other
None
Already a BobCAD Customer?
Yes
No
BobCAD-CAM milling software delivers the functionality you need to complete everything from simple 2.5 axis cutting to complex 4 & 5 axis simultaneous milling. It incorporates a full range of sophisticated and fully associative machining strategies through a simple wizard driven interface to make programming quicker and easier, even for new and occasional users. Dynamic Machining Strategies™ minimize your programming time by allowing you to assign multiple machining strategies to a single feature while advanced simulation functionality lets you test and confirm your work to give you the peace of mind in your CNC programming.
Features of BobCAD-CAM for CNC Mill
Powerful & Standard File Translators
BobCAD-CAM software is compatible with a large variety of file formats to give you the flexibility needed when working with client files. (DXF, DWG, IGES, STEP, SAT, 3DM, X_T, X_B, SLDPRT, STL)
Post Processor Library
BobCAD-CAM offers a large library of downloadable post processors that work with variety of machine types from many of the biggest machine manufacturers in the industry. Customize the post to fit your specific machine requirements or BobCAD-CAM can customize a post for you.
Advanced 2, 3, 4, & 5 Axis Toolpaths
The BobCAD-CAM milling software offers a wide variety of powerful toolpath strategies to give you advanced control over how you target your part. Take full advantage of your CNC milling machine with adaptive high speed toolpaths, 4 & 5 axis simultaneous machining, and other advanced milling capabilities.
Solid Simulation with Machine Components
Utilize your machine’s configuration and kinematics to test and confirm your mill programming before ever cutting a chip. Use it to view the complete milling process, detect machined part deviations and collisions, calculate cycle times, and more!
Multiple Jobs & Multiple Setups
BobCAD-CAM’s comprehensive milling solution allows you to program multiple machining centers and multiple part setups for a single job in the CAM tree. Easily create multiple setups in any part origin using BobCAD-CAM’s dynamic part origin to define the X, Y, and Z of your part.
Program From Wire Frame, Surface Edges, Surfaces, or Solids
Toolpaths in BobCAD-CAM support wireframe boundaries, surface edge loops, and constant Z profile to allow you to work directly off surface and solid models. The ability to define hole depths and pockets directly off selected surfaces provide enhanced control for shops working with wireframe drawings or surfaces and solids.
Other Features Include
CAD
CAD Design Tree
Dynamic Drawing
Shape Library
2D / 3D Wireframes
2D Booleans
Project to Z Planes
Cross Section Viewing
2D & 3D Geometry Creation Tools
Surface Construction
Solid Modeling
Solids Boolean Operations & Surface Editing
CAD Utilities, Translation, Mirroring, Stitching & Unstitching
Gear, CAMs & Sprocket Design Wizards
Bolt Hole & Grid Patterns
Text / Font Features & Complete Part Dimensioning
Geometry Cleanup & Optimize with Erase Double Entities
CAD Data Translation & Interoperability
CAM
Tool Crib
Job Setup Wizard
Copy & Paste Operations
Expand & Collapse in Tree
Customizable Setup Sheets
Stock Wizard
Multiple Machine Setups
Material Speed & Feed Library
Tool Holder Library
Individual & Compound Drilling Operations
Tool Database
Material Based Calculated Feeds & Speeds
Ability to Save & Load Features
3D Simulation
Work Offset Selection
Coolant Selection
Sub Program Output
3D Arc Fit – G17, G18, & G19 Plane Cutting
Associative CAM Tree
Mill Toolpaths
2.5 Axis
Profiling
Pocketing
Engraving
High Speed Pocketing
Thread Milling
Plunge Roughing
Facing
Chamfering
Rest Machining
3 Axis
3 Axis Wireframe
3 Axis Planar
3 Axis Spiral
3 Axis Engraving
3 Axis Radial
3D Plunge Roughing
Z Level Roughing
Z Level Finishing
Advanced Roughing
Flatlands
Equidistant Offset
Pencil
High Speed Roughing
Rest Machining
4 Axis
Indexing
Wrapping
Rotary
5 Axis
SWARF Machining
High Speed Multiaxis Roughing
Trimming
Indexing
Surface Based Toolpath (3, 4, & 5 Axis Output)
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves
Project Curves
Morph Between Surfaces
Parallel to Surface
