Open Source Sofware
BobCAD-CAM Version Matrix
32-bit Application
64-bit Application
3DConnexion 3D Mouse Support
Getting Started System
Ribbon Bar Simulation Interface
Network License
Hole Making
Center Drill / Spot Drill
Drill Single Depth
Peck Drill
Tap/Rigid Tap
Thread Library
Rolled Tap
Contor Bore
Multi Size Hole Drilling
Multi Depth Hole Drilling
Hole Geometry Picking from Surfaces
Machining Sequence
2D Milling
Contour Ramp
Side Roughing
Offset Pocket
Zig Zag Pocket
Advanced Pocket (Open Pocketing)
Adaptive Roughing
Thread Milling
Plunge Rough
Rest Pocketing
Corner Round
Taper Thread Milling
Helical Posting for Spiral Leads
Chamfer Roughing
Peck Lead In
Minimize Retracts
Toolpath Extensions (Open Profiles)
Adaptive Facing
Enhanced Geometry Picking
3D Milling
3 AXIS Wire Frame
Z Level Rough
Z Level Finish
Slice Planar
Slice Spiral
Slice Radial
Plunge Rough
Template Strategy
Rest Roughing
Operation Stock
Side and Bottom Allowance
Pick Top/Bottom
Rapid Retract For Large Gaps
Boundry Options (Center, Inside, Outside)
User Defined Tob/Bottom Job Pick
Gouge Checking
Rest Finishing Stock STL
In Process Stock Check Holder
Vertical Arc Leads for Adaptive
Peck Entry
Under Cut
Surface Based Toolpaths
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves
Parallel to Multiple Curves
Project Curves
Morph Between 2 Surfaces
Parallel to Surface
Mirror Toolpath
4 Axis Toolpaths
Wrapping Groups
3+2 Positioning / Indexing
5 Axis Trimming
Multiaxis Roughing
Swarf Machining
Multiaxis Posting Settings for All Milling Features
Trim To Stock
Gouge Check
Adaptive Step Over
CAD Preview
Stretch Function
Spline Modification
Solid Action Tree
Dynamic Drawing and Positioning for 2D and 3D
Shape Library
2D Booleans
Extract Edges - Project to Z
Nonuniform Scaling of Wireframe and Solids
Extrude Boss/Cut
Solid Split
Section View
Swung Service
Ruled Surface
Improved Surface Filleting
Snap Increment for Dynamic Drawing
Spun Profile
Chain Filleting
Quick Unit Access from Status Bar
Multi-Threaded 3 Axis Pro Toolpath Calculations
Full Machine Simulation for Milling and Mill Turn
Tool Crib
Multiple Machining Jobs in One File
Copy and Paste of Features and Operations
Dynamic Machining Strategies (DMS)
Setup Sheets for Mill and Lathe
Apply All Functions in CAM for Faster Programming
Picking Depths from Solid Models for Holes
Dynamic Posting Order
New Ribbon Bar User Interface for Simulation
Workpiece Definition
Update All Geometry (CAM Tree)
Groups (CAM Tree)
Center/Spot Drill
Drill/Peck Drill
Face Rough/Finish
Turn Rough/Finish
Face Groove Rough/Finish
Turn Groove rough/Finish
Taper Thread
Cut Off With Chamfer/Fillet
Stock Handeling
Tap/Rigid Tap
Rolling Tap
Canned Cycle / Seperate Moves
Tip Calculation
Pick Top/ Bottom
Rapid on Exit
Rapid Apporach
Feature Type Programming ( OD ID Front Face Back Face )
Region Programing ( 1, 2)
Remove Undercut
Toolpath Constraints
Toolpath Extention
Standard & Offset Pattern
Standard & ZigZag Sorting
Rough & Finish Allowance
Overlap Control
Round or Sharp Corner
6 Lead In / Out types
Single Pass Groove
Zig Zag Groove
Standard, Center out / Alternate & Skip Groove
Multiple Depths
Stock Tracking / Trim to Stock
Mill TurnV27V28V29V30
Support for Many of the Most Popular Mill Turn / Live Tooling Machines
Multiple Turret Machine Support
Support for Subspindles
Tool Crib for Easy Mounting of Tools and Adapters
5 Axis Milling Spindle Support
Job Setup Wizard
MDI ( Manual Data Input ) for Motion, Part Transfers, Tailstocks and More
Turret and Tool Adapter Library
New Lathe System
Wire EDMV27V28V29V30
Wire EDM Jobs
CAM Wizard
Stock Wizard
Wire EDM Features
2 Axis Inside, 2 Axis Outside and 2 Axis Open (No Taper)
2 Axis Inside, 2 Axis Outside and 2 Axis Open (Constant Taper)
Land and Taper (Land on Top or Bottom)
Cut One or More Profiles in a Single 2 Axis Feature
4 Axis Inside, 4 Axis Outside and 4 Axis Open
4 Axis Syncing
Wire EDM Simulation
Load Vector Files
Image Vectorization - 64 Colors
Emboss Models
Emboss Feature
Wrap Embossed Models
Remove Non-Emboss Area
Save as Component/STL
Emboss from Component Feature
Supress One or More Individual Features
Custom Cross Sections
Material / Texture Selection
V Carve Toolpath
Screen Selection
Batch Selection
Multi Part Nesting
Part Priority
Part Quantity
Sheet Size
Multiple Sheets Supported
Nest Only
Nest & Toolpath
Cut Direction Control
Machine Order Control
Part Rotation
Distance Between Parts
Stock Margin
Fill Order
Part in Part
True Shape Nesting
Export Sheet to DXF
Nesting Job
Nesting Wizard
Layer Sorting Control
Filler Quantity
Angle List
Grain Direction
Advanced Part Parameters
Custom Sheet Shape
Variable Stock Margin
Advaned Sheet Settings
Max Part Distance
Thermal Distance
Cut Large Parts Later
Filler Part Settings
Best Nesting Direction
Nest only full Quantity
Flat End Fit
Nesting Optimizers
Remnant Sheet Settings
