How to Create a Multiaxis Swarf Feature
This tutorial explains how to create a Multiaxis Swarf feature. The goal of swarf milling is to create the desired cut using the entire flute length of the tool. This is great for machining fluid parts such as blisks (bladed disks) and impellers.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Swarf Example 1.sldprt
Once you download and saved the zip file, extract the files on your system in an easy place to remember. You can then open the file to use with this tutorial. All files for the tutorials in this help system available for download can be found by clicking on the following link: http://www.bobcad.com/helpfiles.
In the example file provided, the stock and Machine Setup are already defined for the part. The part is simulated using the BC Table Table machine.
This example uses the Automatic strategy and what is explained here can be applied to the other Swarfing strategies. Adding leads, creating multiple steps, adding a gouge check, and an important note on machine movement are also explained.
Part 1) Add the Feature
In the Property Manager, click the
CAM Tree tab. -
Right-click
Machine
Setup and click Mill Multiaxis. -
In the Multiaxis Wizard, select Swarf Machining.
Click Next>> to go to the Posting dialog box.
The Work Offset # is automatically set to the value defined in the Machine Setup dialog box.
Click Next>> to go to the Multiaxis Posting dialog box.
In the Tool Data group, set the Diameter to 0.75 and set the Corner Radius to 0.00.
Clear the
System
Tool check box, and set the
Flute Length to 2.00. -
Click Assign Tool Holder. (If the Holder Label box displays the tool holder name, skip this step.)
In the Milling Tool Holder Library CAT 40 Holder list, click 0.75 inch I.D. Arbor CAT 40.
(If you assign a tool holder to a tool in the Tool Library, that holder is automatically assigned and Step 2 can be eliminated.)
Click Next>> to go to the Parameters dialog box.
Part 5) Select Geometry
For this example, we are using the Automatic strategy because it always uses a Swarf Surface selection. (We use all of the Automatic options for Swarf and only change what is needed to get the desired result.)
Next to Swarf Surfaces, click
In the graphics area, select the swarf surface as shown next.
OK.
The geometry selection for this example is now complete.
Note: The geometry selections for swarf machining change depending on the Strategy selected. With any strategy, you have the option to select the Upper and Lower Curves which are used to align the tool. The curves are split into equal-length segments and the matching points for each segment are used to create the tool orientation. Selecting the Upper and Lower Curves gives you control of the cutting side and direction for the feature. If you don't select the curves when using the Automatic strategy, the system attempts to find the correct curves and cutting direction automatically using only the selected swarf surfaces.
Part 6) Define the Parameters and Create the Toolpath
To leave material for finishing, in the Swarf Offset box, type 0.30.
Near the bottom of the dialog box, click Retracts.
In the Clearance Area group, confirm that the Type is set to Plane, and the Direction is Z Axis.
Confirm that the Height is set to 4.000.
This value is automatically set (but only when the feature is created) using the Clearance Plane value from the Machine Setup.
You can modify the Clearance Plane for the feature in this location at any time.
Click OK to close the Retracts dialog box.
To view the feature as it is currently defined, at the bottom of the dialog box, click Compute.
The result is shown next.
Notice that the toolpath computed on the wrong side of the part.
This is resolved in the next part of this tutorial.
For you, the toolpath may have calculated on the proper side of the part. If it did, then you do not have to change the Machining Side as explained in the next part.
Part 7) Edit the Feature
Feature Multiaxis
and click Edit. -
On the left side of the Multiaxis Wizard dialog box, click Parameters.
In the Machining group, next to Side, click the arrow and select Left. -
At the bottom of the dialog box, click Compute.
The toolpath is now on the proper side of the part.
Tip: The Automatic options for Swarf machining work well for most parts. In the event that you have trouble creating the proper toolpath, you may want to turn on the Upper Curve and Lower Curve geometry items and assign the edges of the Swarf surface as shown next.
After selecting the Upper Curve and Lower Curve, you can then set the Machining Direction to Follow Lower Curve Chaining and set the direction of the lower curve as explained next.
To view the Start Point, in the CAM Tree, right-click
Lower
Edge Curve and click Modify
Start Point. (You may need to expand the Geometry folder of
the Multiaxis feature.) -
In the graphics area, the start point becomes visible.
To change the start point (direction), click
near the end of the entity, and then click
OK.
In addition to the previous method, to reverse the direction, you can right-click
Lower Edge
Curve, and click Reverse Direction.
Part 8) Add Leads
Notice that the toolpath is plunging directly into the edge of the part geometry. This is not the desired result for this example. (To simulate the feature and review the result, in the BobCAM menu, click Simulation.) Next, you add a lead-in and a lead-out to cause the tool to plunge outside of the part, so that the side of the tool is used to begin the cut.
In the
CAM
Tree, right-click
Feature Multiaxis,
and click Edit.
At the top of the dialog box, click the Link tab. -
In the Entry/Exit group, next to First Entry, (on the right side) select Use Lead-In.
Next to Use
Lead-In, click
to open the Lead-in dialog box.
Notice at the top of the dialog box, that
the
Use Default
Lead-In check box is selected.
To close the dialog box, click OK.
In the Entry/Exit group, next to Last Exit, (on the right side) select Use Lead-Out.
At the bottom of the dialog box, click Default Lead-In/Out.
The Default Lead-In/Out dialog box displays.
In the Lead-In group, next to Type, select Tangential Line.
At the top of the dialog box, next to Copy, click
This copies the Lead-In settings to the Lead-Out group.
To finish and close the dialog box, click OK.
In the Multiaxis Wizard dialog box, click Compute.
To view the result, in the BobCAM menu, click
Simulation.
To learn more, view Getting Started with Simulation.
To close simulation, in the BobCAM menu, click
Exit Simulation.
Part 9) Create Multi Cuts
Now instead of cutting the part with a single slice, multiple slices are created using Multi Cuts.
Edit the feature, click Parameters, and click the Multi Cuts tab.
In the Pattern Slices group, in the Depth Steps box, type 4.
Click Compute.
Notice that the retract moves are again within the bounds of the part. (This is for all links that are not the first entry or the last exit.)
To change this result, Edit the feature, and click the Link tab. -
In the Links Between Slice group, next to Large Moves, select Use Lead-In/Out (on the right side).
Once selected, click
to open the Lead-In/Out dialog
box.
Notice that the
Use Default Lead-In/Out check box
is selected.
In the Multiaxis Wizard, click Compute.
Now all depth steps use the same lead-in and lead-out as the first entry and last exit moves.
New to Swarf, you can now define Extensions for the toolpath in addition to, or instead of using leads. You can define the length to extend the start and end of the toolpath separately or you can define a starting angle from the swarf surface for the start of the toolpath. This is shown at the end of this tutorial.
Part 10) Add a Gouge Check
There may be times when you want to use Swarf machining even though the machining surfaces are not truly flat. This could result in gouging the surface if the feature is defined too close to the target surface. In such a scenario, you can use a Swarf feature to get as close as possible to the target surface before applying a different strategy to finish the part. The Gouge Check can be used to push the tool out of swarf, or away from the target surface. This means that the tool is moved away from the surface by drawing a line between the contact points of the upper and lower rail; the tool is moved away at a right angle to this line.
Edit the Multiaxis feature, click Parameters, and click the Gouge Check tab.
In the Gouge and Excess group, select the
Check
Against Swarf Surfaces check box, and confirm that the Degouge option is selected.
(You must have selected at least one Swarf surface to use this check.) -
If there are additional surface that you want to gouge check, select the
Additional
Check Surfaces check box.
Click
to enable selection
mode, and select the geometry that you want to gouge check (and then
click
OK to confirm the selection).
This can be the part geometry or any other geometry in the graphics area. -
To update the feature, click Compute.
Part 11) Minimize Table Rotations
When creating Swarf features, there may be fast machine movements that need to be minimized. The following option is provided to help reduce these movements.
Edit the Multiaxis feature, click Parameters, and click the Tool Axis Control tab.
Select the
Minimize
Rotation Axis Changes check box. -
To update the change, click Compute.
To view the result, on the BobCAM toolbar, click
Simulation.
This result is a significant reduction of heavy machine movement for the feature.
Part 12) Add Extensions to the Toolpath
Edit the feature and click Parameters.
At the bottom of the dialog box, in the Extensions group, type 1.00 in both the Start and End boxes.
This extends the lead-in and lead-out by the specified value. (You can use these options with or without leads defined for the feature.) -
Compute the toolpath.
This concludes the tutorial.
