How to Create a Multiaxis Wireframe Operation
This tutorial explains how to create a Multiaxis Wireframe operation. The wireframe operation requires a Drive Curve selection to define the toolpath and Orientation Lines selection along the curve to define the tool orientation.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Multiaxis Wireframe Example 1.sldprt
In the example file provided, the stock and Machine Setup are already defined for the part. The part is simulated using the BC Table-Table machine.
In this example, you apply a trim cut to the bottom surface of the part. This example explains how to create all the geometry that is needed for the feature directly from the part model. You also learn how the chain direction of the drive curve and orientation lines define the toolpath. An important section here explains how to set the side tilt angle to create the proper tool orientation for the feature. The last part shows how to force the tool past the drive curve in order to cut with a different part of the flute.
Part 1) Add the Feature
  3. In the Multiaxis Wizard, click Wireframe.
  1. Click Next>> to go to the Tool page.
  1. In the Tool Data group, set the Diameter to 0.375 and the Corner Radius to 0.00.
  2. To assign a tool holder, clickAssign Tool Holder. (If the Holder Label already displays the holder name, you can skip this step.)
    In the Milling Tool Holder Library, in the CAT 40 Holder list, click 0.375 inch I.D. Arbor CAT 40, and click OK.
  3. Click Next>> to go to the Parameters dialog box.
Part 5) Select Geometry
  1. On the Surface Paths tab, in the Edit Curves group, click Drive Curves.
    Rotate the part model so you can view the bottom of the part.
  2. In the graphics area, right-click the inner surface edge of the bottom face as shown next.
    In the shortcut menu, click Select Tangency.
    Img Img
  3. To confirm the geometry selection, click OK.
  4. In the Edit Curves group, click Orientation Lines. The Orientation lines instruct the tool as to how it should be oriented along the cut.
  5. Click to expand the Feature Manager design tree.
    In the design tree, click the Orientation Lines feature.
    The feature name displays in the Selected Items box.
  6. To confirm the selection, click OK.
Part 6) Set the Direction of the Orientation Lines
You must confirm that all of the Orientation Lines share the same chain direction. For this example, all of the Orientation Lines must point towards the outside of the part.
  1. To view the chain direction, first click Finish to close the wizard.
  2. In the feature in the CAM Tree, right-click Orientation Lines and click Modify.
    (You may need to expand the Geometry folder under the Multiaxis operation.)
  3. The start point of each orientation line is now visible in the graphics area.
  4. To change the chain direction, click near each entity in the desired direction as shown next.
    Img Img
  5. Continue this process until the direction of all orientation lines point to the outside of the part.
    Img Img
  6. To accept the changes, in the Property Manager, click OK.
Tip: As shown in this example, the chain direction of the Orientation Lines is set to start at the tool tip and point back towards the spindle. The chain direction does not point towards the tool tip.
If an error message displays a warning about antiparallel lines, then all of the Orientation Lines are not pointing in the same direction. Repeat Modify Start Point and correct the backwards chain direction.
Part 7) Set the Direction of the Drive Curve
  1. The chain direction of the drive curve must also be set.
The Drive Curve chain direction must be set to properly define the cutting direction and side based on the feature (open or closed) and the selected operation parameters.
To properly set the direction, first press CTRL+1 to select the Front view of the part model.
  1. To hide the part, in the Feature Manager design tree, click Part Model and click Hide.
  2. To view the chain direction, in the CAM Tree, right-click Drive Curves, and click Modify.
    You may need to zoom-in to view the start point.
  3. Confirm that the chain direction is counter-clockwise as shown in the previous image.
Regardless of the current direction, click OK.
If the direction was clockwise, right-click Drive Curves, and click Reverse Direction.
Part 8) Define the Parameters
  1. Right-click Feature Multiaxis and click Edit.
Click Parameters.
In the Pattern group, the Maximum Snap Distance defines what Orientation Lines are included in the toolpath calculation. This distance is measured from the selected Drive Curve.
For this example, because the orientation lines touch the drive curve, the default value of 0.100 is used.
  1. Because the chain direction is counter-clockwise (using the Front view), set the Machining Side to Right.
  2. In the Sorting group, next to Direction for One Way Machining, select Follow Curve Chaining.
  3. To create the feature toolpath, at the bottom of the dialog box, click Compute.
The toolpath is currently at the selected drive curve edge, which is not the desired result.
To view the location of the toolpath compared to the drive curve, in the CAM tree, click Drive Curves.
The drive curve preview displays in the graphics area.
Currently the tool orientation is not the same as the selected Orientation Lines. The Tool Axis Control contains a tilting parameter, Tilt Away from Line, that determines the amount of side tilting applied to the tool from the Orientation Lines in the direction of cut.
Important: In order to have the tool orientation follow the same orientation of the selected Orientation Lines, you must define the Tilt Away from Line parameter as 0.00 degrees.
Part 9) Define the Side-Tilt Angle
  1. Edit the feature, and click Parameters.
  2. Click the Tool Axis Control tab.
    Notice the tilting strategy, next to Tool Axis Will, is set to Be tilted relative to cutting direction.
  3. In the Tilt Away from Line box, type 0.000.
  4. To calculate the toolpath, click Compute.
The toolpath is now offset to the bottom side of the part. This is the desired result.
(To show the part, in the Feature Manager design tree, click Part Model and click Show.)
  1. To view the simulation, .
During simulation, the tool orientation is now the same as the Orientation Lines.
  1. To close simulation, in the BobCAM menu, click Exit Simulation.
When you simulate the program, the machine table is sometimes rotated in a way that doesn't allow you to view the part without rotating the view of the machine. You can change the Angle Pair settings for the feature to modify the table rotation used in simulation and in the posted code.
  1. To edit the feature, in the CAM Tree, right click FeatureMultiaxis, and click Edit.
  2. Click the Multiaxis Posting icon in the tree.
  3. Clear the Use Machine Settings check box.
  4. In the Angle Pair group, next to Use, select Other Solution.
    When you simulate the program again, you can now view the part being cut from the opposite side of the machine.
    The table is rotated to use the other solution to the rotation angles of the primary and secondary rotary axes (angle pair). This changes the posted output of the program as well as the simulation.
Tip: You don't have to compute the toolpath to update this setting for simulation, but you must Post the program to update the code if has already been posted.
Part 10) Axial Shift
If you want to force the tool past the drive curve in order to cut using more of the flute, or a different part of the flute, you can use the Axial Shift parameters.
  1. Edit the feature, click Parameters, and click the Utility tab.
  2. In the Axial Shift group, notice the option Constant for Each Contour.
    This shifts the tool by the specified amount for the entire toolpath.
  3. In the To box, type -0.250.
    (Negative values cause the tool to in-feed, and positive values retract the tool.)
  4. To add the changes, click Compute.
The result is visible in the toolpath display.
The following images show the tool position before and after adding the Axial Shift.
Before After
This concludes the tutorial.
Multiaxis Wireframe
