In this Topic Show
The Parameters page of the Lathe Center Drill operation contains the variables needed for the feature.
Center Drill Depth - is the total depth from the Top Of the Part.
Center Diameter - is the diameter of the center drilled hole on the face of the material being drilled.
Center Angle - is the inclusive angle of the center drill for the operation.
