GearWizardIconWhite.png Parameters
This topic explains the Parameters page of the Chamfer operation found in the 2 Axis Wizard.
GearWizardIconGray.png Parameters
Tool Position
Depth
NOTE:      If the Chamfer Mill operation is added to a Hole feature, the Pick Bottom option will not be available.
Method
CheckBoxCleared.png Stepover - With this check box cleared, no stepover will be used.
Click here to see an example of Minimize Retracts.
IMPORTANT:     Normally, at the end of a pass, the tool retracts to the rapid plane, moves to the X, Y position of the next cut, rapids down to the feed plane, feeds to the proper depth, then starts the next pass. Minimize Retracts will help to eliminate moves back to the rapid plane between passes with a few exceptions:  If the direct link intersects with any part of the toolpath chain, the toolpath will go to the rapid plane between passes. If the direct link is on the opposite side of the offset direction, the toolpath will go to the rapid plane between passes. When no offset direction is set by system or machine compensation, left side compensation is assumed by the system.
Clicking Next> > takes you to the next page of the Mill 2 Axis Wizard. To move to the corresponding topic, click the appropriate link below.
The Profile Rough Leads page
The Profile Finish Leads page
The Pocket Leads page
The Facing Leads page
The Chamfer Mill Leads page
The Corner Rounding Leads page
