Equidistant Operation Overview
The purpose of the Equidistant operation is to create a pattern whose passes are the same distance from each other regardless of the angle of the surface. Exactly how this operation is performed is dictated by the settings in the subsequent pages of the operation. Each of the pages allows you to define the  variables in order to tailor the machining process to fit your needs. Use the following links to jump to the specific topics for each available operation page:
Patterns
Leads
Links
Gouge Check
