In this Topic Show
Mill Turn Features can be thought of as simply as you would the features of the final product itself. For any feature of the part itself, work will have to be done to create it. Any work you choose to do on a feature will be an operation that you add. To create a feature, right-click on the Machine Setup and choose one of the available Mill or Lathe features. Once the feature is chosen and the Wizard is launched, you will be able to select any number of operations needed to complete the chosen feature.
When the feature is finished, the feature is added to the Mill Turn Job in the CAM Tree. All of the information from the wizard can be viewed or modified using the feature in the CAM Tree. Each item of the feature contains a shortcut menu for you to access various functions and commands.
