The Mill Turn Job
The Milling Job in the CAM Tree provides the tools needed to define job settings, machine and post processor selection, tools, stock, stock material, and Milling features. It is also used to create index systems, wrapping groups, and toolpath patterns. This topics explains everything that is included in the Milling Job in the CAM Tree.
To create a Milling Job, use one of the following two options:
The Machining Job dialog box displays.
You can also click to select the Stock Wizard button to open the Stock Wizard and define the stock and machine setup for the job.
The Mill Turn Job in the CAM Tree
CAMDefaultsIcon.png Mill Turn Job
TreeMinusThruLines.pngMachDefMachIcon.png Machine
TreeLinesNoBranches.png TreeLinesElbowEnd.pngPostProcessorIcon.png Post Processor
TreeLinesBranch.pngMillingToolsIconWhite.png Mill Turn Tools
TreeMinusThruLines.pngMillingStockIconWhite.png Stock
TreeLinesNoBranches.pngTreeLinesElbowEnd.pngMaterialStockIconWhite.png Stock Material
TreeLinesBranch.pngMillingStockIconWhite.png Workpiece
TreeMinusWEndLines.pngMachineSetupIcon.png Machine Setup
      TreeLinesElbowEnd.pngMachDefMachIcon.png Submachine
All of the job items in the tree contain a right-click shortcut menu that is used to access the commands as explained next.
The Shortcut Menus
Job Settings, Commands, and Setup Sheets
Right-click Mill Turn Job to open a shortcut menu with the following commands.
TIP:   When the Setup Sheet information displays, you can use the File - Save As command of the browser to save the file to another format or for later use. You can also print the setup sheet using the File - Print commands of the browser.
Click here to go to the Machine Selection topic.
