The Current Settings Default for Wire EDM
The Current Settings dialog box controls various machine and posting parameters. You can define and modify the machines that you use in order to create proper NC programs and simulation. Setting these options to reflect what the machine is capable of is an important part of properly setting up the software. The settings in this dialog box apply to the selected machine and are saved when you click OK. When you click Save As Default, the machine and the current settings are used as the default for each new Wire EDM Job that is created.
This topic describes the Current Settings Default dialog box parameters that become available when a Wire EDM machine is selected in the Machine Parameters section. To learn about all other machine types, view the Current Settings Default Dialog Box topic.
To access the Current Settings Default dialog box to set the system defaults (for new files):
To access the Current Settings Job dialog box and update settings for the current job only:
 MillingToolsIconWhite.png Machine Parameters
The Machine Parameters page of the Current Settings is used to select a default machine, modify an existing machine, or to create a new machine. All of these actions are performed using the Machine group as explained next. When you select a machine in the Machine group, all of the parameters contained in the Current Settings dialog box (for all pages) pertain to that machine.
Machine
4 Axis Output
The 4 Axis Output group is only shown when a Wire EDM machine is selected. Select the Type from one of the two following options to define the output type of 4 Axis Wire EDM programs.
Add/Modify Machine Dialog Box
Cutting Conditions Database
Use Cutting Conditions
CheckBoxSelected.png Select the check box when using the Cutting Conditions Database that is provided with the software. You can then click Select to assign the appropriate database file to the machine.
CheckBoxCleared.png Clear the check box when not using the Cutting Conditions Database. The Select option no longer displays. When you clear the check box, the Link to Database check box in the Wire EDM Wizard becomes disabled for all features.
Use CT Expert
CheckBoxSelected.png Select the check box when using the Cutting Technology Expert database for Charmille machines only. You can then click CT Expert to assign the appropriate database file to the machine.
CheckBoxCleared.png Clear the check box when not using the CT Expert for Charmille machines.
Use Machining Registers
CheckBoxSelected.png Select the check box when manually editing the machining registers for Agie machines. The four available registers are added to the Cutting Conditions page of each operation in the Wire EDM Wizard.
CheckBoxCleared.png Clear the check box to not allow editing of the machining registers.
CheckBoxSelected.png Select the check box when your Wire EDM programs use submerged machining.
CheckBoxCleared.png Clear the check box when your Wire EDM program does not use submerged machining.
 MachDefIconMillSettings.png Machine Definition
The Machine Definition for Wire EDM is currently predefined. You can view the Machine Definition, but you can't update any parameters on the Machine Definition page. All machine parameters are defined by the remaining pages in Current Settings.
 MachDefIconMillSettings.png EDM Setup
This option determines the system default setting in the Wire EDM Wizard for creating Land and Taper operations.
CheckBoxSelected.png Select the check box to extend the graphical display of the wirepath for each Land and Taper operation to the vertical extents of the feature.
Taper_Extend_On.png Taper_Extend_On1.png Taper_Extend_On2.png Taper_Extend_On3.png
CheckBoxCleared.png Clear the check box to turn off the extended taper display. The wirepath for each operation displays only in the areas they cut as if looking at the finished part or feature.
Taper_Extend_Off.png Taper_Extend_Off1.png Taper_Extend_Off2.png Taper_Extend_Off3.png
Output
CheckBoxSelected.png Select the check box to allow the software to output auto threading codes for machines equipped with an auto threader.
CheckBoxCleared.png Clear the check box to not allow auto threading code output.
CheckBoxSelected.png Select the check box to output a separate start hole program in addition to the normal NC program output. You must have the proper Hole Post processor defined on the posting page.
CheckBoxCleared.png Clear the check box when not outputting a start hole program.
 PostProcessorIcon.png Posting
Post Processor
Post Output
Output Options
Program
Subprogram
CheckBoxSelected.png Select the check box to generate repetitive subprograms in the posted NC program, if the post processor is set up to do so.
CheckBoxCleared.png Clear the check box when not generating subprograms.
The following two options are only available when the Output Subprograms check box is selected.
CheckBoxSelected.png Select the check box to allow the Cutting Conditions to be output.
CheckBoxCleared.png Clear the check box to not allow Cutting Conditions to be output.
CheckBoxSelected.png Select the check box to allow the automatic comments to be output.
CheckBoxCleared.png Clear the check box to not allow the automatic comments to be output.
CheckBoxSelected.png Select the check box to output each operation to a separate file. This must be configured in the post processor.
CheckBoxCleared.png Clear the check box to output the entire program in one file.
CheckBoxSelected.png Select the check box to output markers in NC program that can be used to modify or reformat the code after it is post processed. When enabled, post block 75 is called to output new file header code in the NC program. This post block requires the post processor to be customized to function properly.
CheckBoxCleared.png Clear the check box to output the NC program without file breaks.
CheckBoxSelected.png Select the check box to output the guide positions of the program.
CheckBoxCleared.png Clear the check box to not output guide positions.
Cutting Parameters
The Cutting Parameters only display when Sodick AQ325 or AQ537 machines are selected.
After Defining Current Settings
When you are finished with all Current Settings, click OK to save all of the settings with the selected machine. After you have defined all of your machines in the Current Settings Default, they are then available for all new CAM Jobs and can be selected per job from the Current Settings Job. To learn more, view the links listed next.
The CAM Overview
The Wire EDM Job Current Settings Dialog Box
