V-Carve Engraving
The V-Carve feature type is generally used to engrave text, arcs, lines
and splines in a 3-dimensional form with 3 axis tool motion, with pocketing
of open spaces in the selected profiles if necessary. There are two V-Carve
operation types, Tapered Pocketing and V-Carve Finishing (engraving).
This example uses the V-Carve Finishing operation.
Engraving a TrueType
font with V-Carve example:
- In the File menu, click
New.
- In the Text
menu, click Text.
In
the Data Entry Manager:
The
Windows Font button should be selected by default.
In the Font
box, click the down arrow, scroll down, and select Book
Antiqua.
Click anywhere In the Text
box (the blank white box under the font), and type BobCAD-CAM.
Change the Height
value to 2.000.
Click the Drag
button to turn it off.
Click
OK.
The
text is created at X0 Y0 Z0 in the Workspace.
(Click anywhere in the Workspace and press F
to activate the Fit All command, which is also found in the View menu.)
Click Cancel
in the Data Entry Manager.
- Click the CAM Tree tab
at the bottom of the Data-CAM Tree
Manager.
- Right-click CAM Defaults,
and click New Job.
- With the Milling job type
and the BC 3X Mill machine
selected, click Stock Wizard.
- Click the
(next)
button to skip the workpiece assignment.
- With Rectangular selected,
click
- The software automatically creates a bounding stock for the text
in the Workspace.
- Click
to go to the Machine
Setup.
- For this example, we use the default settings, but click the Work Offset button. Next to Z, change the value to 1.000
and click OK.
- Click OK to finish the
Machine Setup.
- In the CAM Tree, right-click
Machine Setup, and click Mill V-Carve.
- In the Mill V-Carve Wizard,
click the Select Geometry
button.
- Click to select the text in the Workspace and click
(OK) to confirm the selection
and return to the wizard.
- Click Next>> to go
to the Feature page.
- Note the Total Depth value.
Setting the Total Depth value here sets the Pocket Depth value for
the Tapered Pocketing operation (and the for the Finishing operation
when using a V-Tool to pocket.) For this example, changing the depth
does not change the toolpath calculation. For more information view
the V-Carve
Operation topic.)
to the Machining Strategy. Notice under Current
Operations, a single V-Carve Finishing operation
is already selected.
- In the tree on the left, click V-Tool
to go to the Tool page. For this example, we use the
default 0.5000 inch diameter
V-tool. Note the selected tool size does change the toolpath calculation
for V-carve finishing operations.
to the Parameters. Notice under Depth
Options, the V-Tool Depth
of Cut parameter. This value is used to limit
the depth when the width of the geometry profile is greater than the
width of the tool. Again, we use the default settings for this example.
For more information on specific parameters view the V-Carve
Operation and the Mill
Wizard topics.
- At the bottom of the wizard, click Compute.
To view the toolpath simulation, right-click Milling Job and click Simulation.
For more information on using simulation, view Getting
Started with Simulation.
