How to Use Edit Toolpath - Break
This example explains how to use the Break option in the Edit Toolpath dialog box. On our example part, we have used a solid model to set the stock to a specific shape. In this case, the stock shape shows what the first two operations have left. Due to the size of the rough tool, much more material has been left in the acute angles of our pocket. It is because of this,  it would be beneficial to slow down the feedrate on our finish operation before it engages that extra material. To accomplish this, we will need to break the toolpath elements leading into, and out of, our acute angles. Once this is accomplished, we can adjust the feedrate on the specific portions of toolpath that engage the leftover material, which will be accomplished in another example. This example will have you:
Example Part
The part file for this example is available for download at: http://bobcad.com/helpfiles. If you are connected to the Internet, you can click the link provided to download and save the Toolpath_Editor_Break_Example BBCD.zip file. After extracting the zip file, you can open the file to follow along with this example. In the example file provided, the stock and Machine Setup are already defined for the part, and the toolpath to be adjusted has been applied.
 Take a moment to look at the stock compared to the existing toolpath to see the what we intend to accomplish.
1      In the Data-CAM Tree Manager, click the CAMTabIconBBCD.png CAM Tree tab.
2      In the CAM Tree, click MllingStockIconWhite.png Stock to view the assigned stock.
Take a moment to look at the existing stock compared to the existing toolpath to get an idea of where we would like to break our toolpath elements.
3      In the CAM Tree, click the Pocket operation in the feature to remove focus on the stock and to place focus on the toolpath to be adjusted.
1      Right-click the Profile Finish operation of the second Feature 2 Axis.
2      Select Edit Toolpath.
The Edit Toolpath dialog gives you access to eight different Command Modes. For this example, we will be utilizing the Break Command Mode.
1      Click the arrow on the Command Mode list to view the list items.
2      Select the Break option.
3      By default, the Preview check box is already selected. Leave this check box selected, as it will allow us to see a preview of the executable result.
Part 4) Adjusting Parameters
Change Parameters to the Screen Point option.
1      Select the Screen Point option in the Parameters group.
Part 5) Selecting Toolpath Elements
1      In the graphics area, select the toolpath shown in the images below.
Part 6) Adjusting Distance
With the toolpath elements selected, we will need to define the distance of the Break Point.
1      In the Break Point list, select Break Point - 1.
Break Point - 1 highlights in the graphics area.
2      Change the Distance to 70.
3      In the Break Point list, Select Break Point - 2.
Break Point -1 adjusts its position in the graphics area and Break Point - 2 highlights.
4      Change the Distance to 30.
5      In the Break Point list, Select Break Point - 3.
Break Point -2 adjusts its position in the graphics area and Break Point - 3 highlights.
6      Change the Distance to 70.
7      In the Break Point list, Select Break Point - 4.
Break Point -3 adjusts its position in the graphics area and Break Point - 4 highlights.
8      Change the Distance to 70.
Part 7) Executing the Action
1       Click Execute.
The toolpath elements update.
Part 8) Viewing the Animation
1      Select the check box for Animation.
2      Use the Animation controls to play through the animation. With either the ToolpathEditor_Animation_SolidIcon.png (Solid), ToolpathEditor_Animation_TransparentIcon.png (Transparent), or ToolpathEditor_Animation_WireframeIcon.png (Wireframe) view.
CAM_EditToolpathBreak_Animation_Solid.png   CAM_EditToolpathBreak_Animation_Transparent.png   CAM_EditToolpathBreak_Animation_Wireframe.png
1      Click OK.
This concludes this example.
