In this Topic Show
Whether a groove is placed on a part for the fitting of another part, or for an O-ring, and whether the groove is square, round or angular, a groove is an indention on the part. As such, the Groove feature will allow you to create an indention of any size or shape needed on the part. The Lathe Grooving feature offers two operations, each of which has many variables that can be tailored to your needs.
Rapid Plane - is the height at which the tool can rapid safely within a single operation. This value visualized as a dotted line in the toolpath and is an incremental distance above the Top of Feature defined in the Constraints section.
Rapid Crashing |
Rapid Lifted |
NOTE: Rapids that are going through portions of the part are not highlighted in the software but merely go straight through. This rapid has been highlighted for visual aid in this help system.
Feature Type
OD - Sets the feature to the outer diameter of the part.
ID - Sets the feature to the inner diameter of the part.
Face - Sets the feature to faces normal to Z+.
Back Face - Sets the feature to faces normal to Z-.
1 - See examples.
2
- See examples.
OD |
OD Region 1 |
OD Region 2 |
ID |
ID Region 1 |
ID Region 2 |
Face |
Face Region 1 |
Face Region 2 |
Back Face |
Back Face Region 1 |
Back Face Region 2 |
NOTE: Region selections are not only for particular sections of the part. Even though, for a given situation, a particular region choice will set the feature up to be better suited for the task, the user may adjust the remaining parameters to match their particular needs.
Rotate - Selecting this check box will give you the ability to rotate the feature so the toolpath is aligned with the geometry. This can be done with:
Angle - Type in the angle the feature is to be rotated.
Pick - Select pick to hide the Lathe Wizard and launch Pick Angle in the Data-CAM Tree Manager.
Pick Wall - allows you to click an entity to set the toolpath parallel to. Clicking the entity once will finalize the selection and reopen the Lathe Wizard.
Pick Floor
to set the toolpath perpendicular to. Clicking the entity once
Lathe Feature |
Rotated Lathe Feature |
The constraints define the area in which the toolpath will be generated.
Top of Feature - Defines the height at which the rapid plane will be incremental from.
From Stock - Sets the Top of Feature to the highest point of the stock diameter. Click here to see an example.
From Feature - Sets the Top of Feature to the highest point of the selected feature geometry. Click here to see an example.
Custom - Set the Top of Feature from the highest point of the selected feature geometry to the value entered. Click here to see an example.
Pick - allows you to select a point or the snap point of an entity to set the height of the feature.
NOTE: The Pick value is incremental from the highest point of the selected geometry for the feature. If geometry selection was skipped at this point, the Pick function will not return a value.
Extensions allow you to extend the feature geometry without the need to create additional CAD geometry. The extension will be added or subtracted along the chain of entities.
Start - is the first of the selected chain of entities.
Distance - sets the amount of extension added to the tangent direction of the chain.
Angle -
While cleared the extension will added to the geometry to the tangent
direction.
Angle -
Select this check box to set the extension at the angle entered.
Relative to geometry -
While cleared the angle of the extension will be absolute.
Relative to geometry - Select this check box to set the
angle of the extension relative to the tangency of the last entity.
End - is the last of the selected chain of entities.
Angle -
direction.
Angle -
Extension Off |
Extension Start On |
Extension End On |
After defining the feature parameters, click Next> > to go to the Machining Strategy page.
