In this Topic Show
Template
Current Operations |
Available Operations |
Rough Basic Finish |
Rough Pattern Repeat Basic Finish
1 The Templates provide predefined groups of operations that can be applied to a feature. Select a template to populate the Current Operations list. (You can customize the Tool Pattern to define the default operations for each template.)
IMPORTANT: When creating Hole or Tap features, the selected Template sets the Cutting Conditions for the feature operations. For this reason, the Template can't be changed when editing a feature. You can still modify the Current Operations, but the Template can't be changed after you click Finish or Compute the first time. When selecting multiple drill hole sizes for a Mill Hole feature, be sure to select the appropriate Template for each feature that is created in the tree on the left side of the Milling Wizard.
2 The Available Operations list displays all operations that exist for the selected feature type. After selecting a template, you can use the Available Operations to add operations to the Current Operations.
3 Finally, you can reorder and/or remove operations from Current Operations to define all of the operations for the feature. (You can modify this list at any time, for example, when editing the feature.)
After defining the machining strategy, click
to go to The
Posting Dialog Box.
The current operations that you selected are created and added to the tree on the left side of the dialog box.
