In this Topic Show
The Parameters page of the Lathe Ream operation contains the variables needed for the feature.
Use Cutting Conditions
this calculates the Overall Depth and Effective Depth for this operation.
Clear the check box to manually change the values that were automatically
calculated.
Effective Depth - the depth from the Top of Feature (face of the feature), excluding the tool tip.
Overall Depth - total depth from the Top of Part (face of the feature), including the tool tip. This value is output in the posted NC program.
