Right-click Post Processor to open a shortcut menu with the following command.
Post Processor
Edit - opens the Set Post Processor dialog box for you to change the post processor that is used to generate the NC Program. This is a quick-change dialog box that is provided for you to change the post processor without the need to open the Current Settings Job dialog box. Click Select to display the Open dialog box, and select a .BCPst file. To update the post processor and close the dialog box, click OK. Click OK again to close the Set Post Processor dialog box.
For information on post processors, follow these links:
Post Variable and API Reference
Advanced Posting with Custom Files
Formatting Post Variable Output
Lathe Scripting Function Reference
Advanced Posting Map Legacy Versions
Click here to go to The Turning Tools topic.
Click here to go to The Milling Tools topic.
