The Posting
Tab
The
Posting tab of the Layer-UCS-Post
Manager displays posted NC programs.
To post the code for any toolpath that has been computed:
- In the
CAM
Tree, right-click the job name (for example,
Milling
Job), and click Post
or click Post & Save As.
The posted NC code is displayed in the
Posting tab.
The Posting Tab Shortcut Menu - How to Save and Edit Code
After posting a program, right-click anywhere in the Posting tab to
display a shortcut menu with the following items. Use these options to
save or edit the code that displays in the Posting tab.
- Save As - opens the Save As dialog box for you to select
a location, name, and save the code as an .nc
file.
TIP: The numerical
control (.nc) file is a text file
that can be edited with any text editor. When you post a program, the
file is automatically saved to the default location for .nc
files: C:\BobCAD-CAM Data\*(Current Version)*\NC\...
- Edit CNC - opens the Predator
CNC Editor with the posted code. Editing, back-plotting, and
other actions can be performed with the editor.
- Mach 3 - if you have purchased
Mach 3, you can open the code in the Mach 3 software.
Post Processors
Machining (Posting) Order Dialog
Box
Getting
to Know the User Interface
