Cross-Section Surface
This topic will explain the Cross-Section Surface function, and the options found in it. This topic will also describe where to find the function, provide quick steps and an example on how to use it, and provide links to related topics.
The Cross-Section Surface Function
The Cross-Section Surface function creates a surface from a group of wireframe curves that are roughly parallel. To perform the function, you chain select each of the cross section entities one at a time, press the Spacebar to confirm the selection, and click OK. You can have as many cross sections as you like, but you must have at least two. The order in which you select the cross sections determines how the surface is created.
To open Cross-Section:
In the Surfaces group, of the Create 3D tab, click
Cross-Section.
Selected Geometry
The list box will list the entities currently selected for the function. |
Quick Steps - Cross-Section
When creating a Cross-Section Surface, you complete one chain selection for each cross section. Each chain can be one or more entities. The selection order determines the results, and the chains should all share the same general direction, such as left to right.
Open the function.
The Selected Geometry list automatically has focus. -
Chain select the first chain.
Tip: To chain select an entire chain, hold Shift and click near the end of the last entity to set the start and end of the chain in one click. To select a portion of a chain, click near the end of the first chain entity to set the start of the chain, then hold Shift and click near the end of the last entity to set the end of the chain.
Chain select the second chain using the same direction as the first chain.
With two chains selected, the Preview appears. -
Repeat this process until all cross sections of the surface are selected and using the same direction.
The Preview updates with every new cross section added to the Selected Geometry list. -
To create the surface, in the Data Entry Manager, click OK.
This example will demonstrate how to use the Cross Section function.
In the quick access toolbar, click
Open.
Select cross section surface example.bbcd, and click Open.
The file opens.
Cross-Section.
The Cross Section Surface parameters display in the Data Entry Manager. -
Highlight the entity as seen in the image below.
Click the entity to set the start of the chain.
Highlight the end of the chain as seen in the image below.
Press and hold Shift on the end of the entity to set the end of the chain.
Tip: To chain select a portion of a chain, as we have done here, click near the end of the first chain entity to set the start of the chain, then hold Shift and click near the end of the last entity to set the end of the chain. To select an entire chain at once, hold Shift and click near the end of the last entity to set the start and end of the chain in one click.
Tip: While selecting the geometry for a cross-section, you can click the start arrow to change the direction of that cross section, or use the Reverse button after highlighting that chain in the Selected Geometry list of the Cross Section Surface parameters in the Data Entry Manager. It is important that all of the cross sections share the same direction.
Hover over the end of the next chain, as seen in the image below.
Press and hold Shift, and click the end of the entity to chain select the entire chain.
With two cross sections added to the Selected Geometry list, the Preview displays. -
Repeat step 11 for each of the subsequent chains, in order, until all are added to the Selected Geometry list.
Notice the difference between the two sides. Even though the last four chains are mirror images of the first four chains, selecting only a portion of the first chain, as we have done, has created some irregularities. We will correct that in the next steps. -
In the Selected Geometry list, click on Chain-1 to highlight it.
The chain highlights in the graphics area. -
Click
(Delete) to remove the partial chain from the list.
Tip: You can also right-click a chain in the list to gain access to the same controls seen on the buttons.
The Preview updates.
Hover over the end of the deselected chain as seen in the image below.
The chain is added to the Selected Geometry list as Chain-10 and the Preview updates.
Because the order of the chains in the Selected Geometry list is wrong, the Preview show an unintended result. We will correct that in the next steps. -
In the Selected Geometry list, click Chain-10 to highlight it.
Click the
(Move Up) button to move Chain-10 up the list.
The order is still off. We need to move Chain-10 to the top of the list. -
Click the
(Move Up) button to move Chain-10 up the list, until it is at the top of the list.
The Preview updates. -
Click OK to finalize the Cross Section.
The surface is created and aCross Section feature is created in the
CAD Tree.
