The Evaluate Ribbon
This topic will explain the Evaluate Ribbon, and all the options found in it.
The Evaluate Ribbon
The Evaluate Ribbon is divided into groups, each group shows like functions, with functions that are used more often having a larger icon to make it easier to get to.
Dimension
Auto - is designed to replace all other dimension creation options in the Dimension group with the exception of Chain, and Reference. -
Radius - allows you to select a radius to create a dimension on it. -
Angle - allows you to select two non-parallel lines to create an angle dimension on. -
Horizontal - allows you to select two points to create a dimension representing the distance in X. -
Vertical - allows you to select two points to create a dimension representing the distance in Y. -
Other Distance
- allows you to select two points to create a dimension representing the distance in X, Y, and Z. -
Point - allows you to select a point to create a dimension representing its location in X, Y, and Z. -
X-Ordinate - dimensions a distance along the X-axis, and places the text parallel to the Y-axis. -
Y-Ordinate - dimensions a distance along the Y-axis, and places the text parallel to the X-axis. -
Chain - uses the end of an existing dimension as the reference
for the next dimension. -
Reference - uses the start of an existing dimension as the reference
Annotation
Note - is used to create text that is placed in the graphics area along
with a leader, or multiple leaders, ending in a terminator for the purpose
of drawing attention to something in the drawing. -
Cross Hatch - is used to fill a contour, or closed chain of entities, with repeating line segments.
Modify Dimensions
Move - is used to manually adjust the position of existing dimensions. -
Align Horizontal
- is used to adjust the vertical position of existing dimensions in order to align their values horizontally with another dimension. -
Align Vertical
- is used to adjust the horizontal position of existing dimensions in order to align their values vertically with another dimension.
Measure
Measure One - measures various dimensions of a single entity. -
Measure Two - measures various dimensions of, or spaces between,
two selected entities.
