The Home Ribbon
This topic will explain the Home Ribbon, and all the options found in it.
The Home Ribbon
The Home Ribbon is divided into groups, each group shows like functions, with functions that are used more often having a larger icon to make it easier to get to.
Edit
Delete
- The Delete command is used to eliminate or remove currently selected
geometry from the Workspace. You must first enable selection
mode. -
Cut
- The Cut command is used
to remove selected geometry from the Workspace and add it to the clipboard
(it can then be pasted). You must first enable selection
mode. -
Copy
- The Copy command adds any
selected geometry to the clipboard, which can then be pasted. You
mode -
Paste
- The Paste command is used to place (paste) geometry from the clipboard
into the active Workspace. This only works if you have Cut or Copied
geometry into the clipboard first. The geometry is placed in the same
location and position from which it was Cut or Copied, but it is placed
on the currently Active CAD layer. You must first enable selection
mode.
Selection
Select
Mode - enables selection mode. -
Select
All - selects all visible entities. -
Clear -
removes all the current selections. -
Add/Remove
Toggle - sets the selection mode to add or remove entities.
Click an entity once to select it, click it again to clear the selection. -
Add
to Selection- sets
the selection mode to add selections only. -
Remove
from Selection - sets the selection mode to remove selections
only.
Quick Selection
Pick
By Layer - opens the Select
Color dialog box. Select a color, and click OK
to select all visible entities of the same color. -
Pick
By Color - opens the Select
Layer dialog box. Select a layer, and click OK
to select all visible entities in the layer. -
Pick+Match
Layer - is used to select an entity and have all of entities
on the same layer automatically selected. -
Pick+Match
Color - is used to select an entity and have all of the
same colored entities automatically selected. -
Pick+Match
Radius - is used to select an arc and have all entities
of the same radius automatically selected. -
Pick+Match
Line Style - is used to select an entity and have all
entities that have the same line style automatically selected.
Modify
Entity -
opens the Data Entry Manager so you can modify the parameters of the
selected entity. You must select a single entity (whether or not it
is a part of a contiguous entity chain), such as one line or one arc,
or this function is unavailable. This option is used for wireframe
entities, including text. To learn more, view How
to Modify Wireframe Entities. -
Modify
Color - opens the Modify Color dialog box.
Click the new color, and the selected entity is updated. -
Modify
to Current Color - changes the selected entities to the
active color. -
Modify
Layer - opens the Select Layer dialog box. Click
the layer to which the selected entity is moved, and click OK. -
Modify
to Current Layer - places the currently selected entities
on the active layer. -
Modify
Line Style - opens the Line Style dialog box.
Click the new line style to apply to the selected entity, and click
OK. -
Modify
to Current Line Style - changes the selected entities
to the active line style. -
Modify
Point Style - opens the Point Style dialog
box. Click the new point style to apply to the selected entity, and
click OK. -
Modify
to Current Point Style - changes the selected points to
the current point style. -
Change
Style to Solid - converts selected entities to a solid
line style. -
Change
Style to Dashed - converts selected entities to a dashed
line style.
Selection Mask
The selection masks can be used to control what entity types can be selected in the graphics area. When you enable selection mode, you can click an icon to disable the ability to select that entity type.
All
Mask - selects all selection masks so that all entity
or dimension types can be selected. -
Solid
Mask - controls
the ability to select solid geometry. -
Surface
Mask - controls
the ability to select surface geometry. -
No
Mask - clears the selection of all selection masks
so that no entity or dimension types can be selected. This makes it easier when
you only want to turn on a small number of selection masks. -
Pattern
Mask - controls the ability to select point pattern geometry. -
Point
Mask - controls the ability to select point geometry. -
Text
Mask - controls the ability to select text geometry. -
Line
Mask - controls the ability to select line geometry. -
Dimension
Mask - controls the ability to select linear dimensions. -
Arc
Mask - controls the ability to select arc geometry. -
Radius
Dimension Mask - controls the ability to select radial
dimensions. -
Spline
Mask - controls
the ability to select spline geometry. -
Angle
Dimension Mask - controls the ability to select angular
dimensions. -
Contour
Mask - controls the ability to select contour entities. -
Point
Dimension Mask - controls the ability to select point
dimensions.
Coordinates
Turning Mode - Toggles from the standard WCS
to
to allow drawing to be done using coordinates in line with lathe output.
