Ruled Surface
This topic will explain the Ruled Surface function, will explain where to find the function, and explain the options found in it. This topic will also explain creation with quick steps and an example, and provide links to related topics.
The Ruled Surface Function
The Ruled Surface function creates surfaces using the selection of two wireframe chains with a linear blending between the entities of each chain. The two chains need to share the same general chain direction to create the proper results. The two chains can be connected to form the boundary of the surface, or the software automatically creates the boundary of two non-connected chains. Generally, the chains should be the same number of entities.
To open the Ruled Surface function:
  • In the Advanced Surfaces group, of the Create 3D tab, click Ruled Surface.
Selected Geometry
(Move Up) - Move the highlighted item up the list.
(Move Down) - Moves the highlighted item down the list.
(Reverse Direction) - Reverses the direction of the highlighted item.
(Delete All) - removes all entities from the list.
The list box will list the entities currently selected for the function.
Quick Steps - Ruled Surface
  1. Open the function.
  2. Chain select the first chain.
  3. Chain select the next chain.
    The Preview appears.
  4. Click OK to confirm creation.
    The feature is added to the CAD Tree.
  5. Repeat as necessary.
  6. Click Cancel to exit the function.
A BobCAD file installed with the software can be opened to follow along with this example.
Part 1) Open the Example File
  3. With Ruled Surface Example.bbcd displaying in the File Name box, click Open.
    In the example file, the geometry for the ruled surface is two 3D spirals (helices) that consist of many line segments. Ruled Surface uses two wireframe chains to create a surface with a linear connection between the chains. For the first part of this example we see the result of the spline curves made of line segments.
Part 2) Open Ruled Surface
  1. In the Advanced Surfaces group, of the Create 3D tab, click Ruled Surface.
Part 3) Select Geometry
  1. Press and hold Shift and click the small line segment at the upper end of the helix.
    The start and end arrows display to show the first chain is selected.
  2. Chain select the second helix using the same method. Be sure to click near the upper end of the helix to define the same chain direction as the first chain.
    When you complete the second chain selection, the surface preview is automatically created.
    Notice the preview of the resulting surface is many small surfaces, one for each set of line segments in the two helices.
    In order to create the surface as a single smooth surface, we use an Approximated Spline to create a single entity from each helix.
Part 4) Create Splines from Curves
  1. In the Layers Manager, right-click Spline and click Active Layer.
    This is done so the splines are created on a separate layer from the original helix geometry.
  2. In the Entity group of the Create 2D ribbon, click the down arrow under Spline, and select Approximated.
  3. In the Points From Mode group, of the Data Entry Manager, select the Multi-Picking option.
  4. Press and hold Shift and click the small line segment at the upper end of the helix.
    The preview of the spline appears.
  5. Click OK to create the spline.
  6. Press and hold Shift and click the small line segment at the upper end of the other helix.
  7. Click OK to create the spline.
  8. To close the Data Entry Manager, click Cancel.
  9. In the Layers Manager, right-click Wireframe and click Hide to hide the original helices.
Part 5) Edit the Ruled Surface Feature
  2. Hover over the first spline, hold shift and left click to select the first chain.
  3. Hover over the second spline, hold shift and left click to select it as the second chain.
    The second chain is added to the Selected Geometry list, and the preview is immediately visible.
  4. Press OK to finalize the Ruled Surface.
Notice the significant improvement in the Ruled Surface as a result of creating the spline curves. The surface is now a single entity. This method can often be used to improve the result of a Ruled Surface when using complex wireframe input geometry, especially when the chains don't contain the same number of entities.
The CAD Overview
