The Assigned Tools Dialog Box (Mill or Lathe)
This topic explains the Assigned Tools dialog, describes where to access it, explains the options found in it, and provides links to related topics.
The Assigned Tools dialog
The Assigned Tools dialog box allows you to verify or change the tool number assignments for the posted program before the NC code is post processed. The Tool List shows all tools that are currently in use for all features in the CAM tree. As you create features, the selected tools are automatically added to the Tool List.
To access the Assigned Tools dialog box, do one of the following:
- In the Job Setting group, of the Machining ribbon, click the down arrow under
 Tools, and select
 Verify Tool Assignment.
- In the  CAM
	 Tree, right-click the Tools
	 icon (for example,
 Milling Tools), and click Verify Tool Assignment.
- From any CAM Wizard Tool page, click Tool Number.
The Assigned Tool dialog box displays.
The Assigned Tools Parameters
Tool List
- Tool Number - displays
	 the assigned tool number that is output for each tool in the posted
	 NC program. The numbering is controlled by the Use Automatic Tool
	 Numbering check box.
 - Tool Diameter - displays
	 the diameter of each tool.
 - Corner Radius - displays
	 the corner radius value of each tool.
 - Tool Type - displays the
	 type of each tool.
 - Tool Label - displays the tool label for each tool.
- Use automatic tool numbering
 Select this check
 box to allow the system to number the tools in the order that they are
 used in the posted NC program. This option ignores the tool numbers assigned
 in the Tool Library.
 Click to clear this
 check box to manually number all of the tools for the program. Once the
 check box is cleared, double-click the desired tool row. The tool number
 box becomes available for you to type a new number. Renumbering tools
 from this location does not change
 the number of the tool stored in the Tool Library. With this option, any
 tools from the Tool Library (called System Tools) use the number assigned
 to the tool in the Tool Library. Be aware that if you create any tools
 in a CAM Wizard (called Manual Tools), the software numbers them using
 the next available tool number at the time created. You must confirm that
 all tools are using the desired tool number before posting the final NC
 program. Note that the software can't eliminate duplicate tool numbers
 when using this method, it is your responsibility.
To renumber tools after post processing, revisit this dialog box and make the required changes. Afterward, right-click the job folder (Turning Job or Milling Job), and click Post. The NC program is updated with the new tool numbers.
