How to Use Edit Toolpath - Extend Cut Move
This example explains how to use the Extend Cut Move option in the Edit Toolpath dialog box. The Extend Cut Move command will allow you to select particular toolpath elements to extend a particular distance. The example provided will have you:
  • Viewing the Toolpath
  • Setting the Command Mode
  • Setting the Parameters
  • Executing the Action
  • Viewing the Animation
Example Part
The part file for this example is available for download at: http://bobcad.com/helpfiles. If you are connected to the Internet, you can click the link provided to download and save the Toolpath_Editor_Extend_Example BBCD.zip file. After extracting the zip file, you can open the file to follow along with this example. In the example file provided, the stock and Machine Setup are already defined for the part, and the toolpath to be adjusted has been applied.
Part 1) Viewing the Toolpath
On our example part, we have roughed out the stock with an Advanced Rough and have finished that up with an Advanced Planar toolpath. In this case, we intend to extend our toolpath elements beyond the edge of the model without rolling over the edge.
  1. In the Data-CAM Tree Manager, click the CAM Tree tab.
  2. In the CAM Tree, click the  Advanced Planar operation of the Feature 3 Axis to highlight the toolpath in the graphics area.
    Take a moment to look at the existing toolpath to see what we intend to accomplish.
  3. Rotate the part into a side view.
  4. Go to the View menu and select Transparent, or use the keyboard shortcut by pressing T on the keyboard.
    Notice the toolpath ends at the edge of the model.
  1. Right-click the   Advanced Planar operation of the Feature 3 Axis.
  2. Select Edit Toolpath.
The Edit Toolpath dialog gives you access to eight different Command Modes. For this example, we will be utilizing the Extend Cut Move Command Mode.
  2. Select the Extend Cut Move option.
    The preview displays.
  3. By default, the Preview check box is already selected. Leave this check box selected, as it allows us to see a preview of the executable result.
Note: By default, the Extend Cut Move command automatically extends the cut moves of the entire operation. If our intent was to extend the cut move on particular moves, we would select those toolpath elements at this point. In this case, we want all of our moves to be extend, and will, therefore, leave the Selected Toolpath Elements empty.
Part 4) Setting the Parameters
At this point, we need to determine how far to extend our cuts.
  1. In the Parameters group, click the % toggle button to change the extension method from a percentage of the tool diameter, to an absolute increment..
  2. Change the extension value to 0.45.
    The preview updates.
Part 5) Executing the Action
  1.  Click Execute.
Part 6) Viewing the Animation
  2. Use the Animation controls to play through the animation. With either the (Solid), (Transparent), or (Wireframe) view.
Part 7) Exiting the Edit Toolpath Dialog
Once the Animation has been viewed to ensure no further edits are needed, click Apply to finalize and Cancel to exit the Edit Toolpath Dialog. If you need to change the toolpath to its original state after clicking OK, recompute the operation.
  1. Click Apply.
    This finalizes the edits.
Important: Keep in mind clicking OK, executes the command and exits the Edit Toolpath dialog. Since we can see a preview for an additional extend move, clicking OK would execute another extension and then exit. It is for this reason that we have used the Apply button and will not Cancel to exit the dialog.
  1. Click Cancel.
This concludes this example.
