How to Use Edit Toolpath - Move
This example explains how to use the Move option in the Edit Toolpath dialog box. The Move command will allow you to select particular toolpath elements and adjust their position. The example provided will have you:
- Viewing the Toolpath
- Opening the Edit Toolpath Dialog Box
- Setting the Command Mode
- Selecting Toolpath Elements
- Setting the Parameters
- Executing the Action
- Viewing the Animation
- Exiting the Edit Toolpath Dialog
Example Part
The part file for this example is available for download at: http://bobcad.com/helpfiles.
If you are connected to the Internet, you can click the link provided
to download and save the Toolpath_Editor_Move_Example
Part 1) Viewing the Toolpath
On our example part, we have used a solid model to set the stock to a specific shape. In this case, we have roughed out the stock with an Advanced Rough and have finished that up with a Flatlands toolpath. It is the rapid heights of the Flatlands toolpath we intend to adjust. Take a moment to notice there is only two rapids, highlighted in red in the images below, that need to be at their current height.
In the CAM Tree, click the Flatlands operation of the Feature 3 Axis to highlight the toolpath in the graphics area.
Take a moment to look at the existing stock compared to the existing toolpath to see what we intend to accomplish.
Rotate the part into a side view.
Notice most of these rapid moves could be lower to save some machining time.
Right-click the Flatlands operation of the Feature 3 Axis.
Select Edit Toolpath.
The Edit Toolpath dialog gives you access to eight different Command Modes. For this example, we will be utilizing the Move Command Mode.
Click the arrow on the Command Mode list to view the list items.
Select the Move option.
By default, the Preview check box is already selected. Leave this check box selected, as it will allow us to see a preview of the executable result.
We now, need to select the Point Pick check box under the Selected Toolpath Elements list so that we can pick the points where the vertical and horizontal rapids meet. Once this is selected, we will move and rotate the part, as needed, to pick all sixteen toolpath points shown in the images below.
Under the Selected Toolpath Elements list, select the Point Pick check box.
This will allow us to pick the point at which two toolpath elements meet, thereby giving us the ability to adjust both elements, rather than just one element or the other. -
In the graphics area, select the toolpath points shown in the image below.
In each of the four corners of the part, there are two rapids. Be sure to pick both points on each of the eight rapid moves.
Note: When toolpath elements are close enough together, attempting to select one may cause a dialog to appear. This dialog will allow you to select, from the dialog list, the intended toolpath element, as seen in the images below.
In the Parameters group, select the Drag option.
Note: The Drag option will allow you to enter X, Y, and Z values in the Delta group to set the distance the selected toolpath is moved. While the Drag option is the default option, clicking the option will cause the drag handles for the axes to appear. These allow you to move the toolpath manually instead of, or in combination with, data entry using the Delta group text fields.
The drag handles appear in the graphics area.
Hover over the Z Axis of the Drag Handle.
The Z Axis highlights.
Click the Z Axis of the Drag Handle.
The Delta group values become unavailable. -
With the Z Axis highlighted, move your mouse up and down and notice the preview adjust.
While the X,Y, and Z values can be adjusted visually, we will enter a value in the Delta Z text field.
Click in the graphics area to set the toolpath wherever it may be.
The Delta values become available again. -
In the Delta Z text field, enter -1.0.
Part 6) Executing the Action
Click Execute.
Part 7) Viewing the Animation
Select the check box for Animation.
The tool appears in the graphics area at the start of our toolpath. -
Use the Animation controls to play through the animation. With either the (Solid), (Transparent), or (Wireframe) view.
Click OK.
Important: Once the toolpath of an operation has been edited, the operation will be locked. In the CAM Tree, to the left of the operation name, which will be shown in red font, you will notice a lock icon: . This ensures the toolpath can not be accidentally recalculated. To return the toolpath to its original state, or to update the operation with the wizard, and recalculate the toolpath, you must first right-click the operation and select Lock/Unlock Operation. The toolpath can then be recalculated to undo the edits that have been made to it with the Edit Toolpath dialog.
This concludes this example.
