Extrude Surface
This topic will explain the Extrude Surface function, will explain where to find the function, and explain the options found in it. This topic will also give a brief description of Dynamic Drawing, the Snap Increment function, explain creation with quick steps and an example, and provide links to related topics.
The Extrude Surface
The Extrude Surface function creates a solid or surface shell by extruding surface geometry.
Tip: This function does not merge the result with other solid bodies. To extrude a surface that merges with other solid bodies, use Extrude Boss.
Dynamic Drawing
Preview with Sketch Handles |
Final Entities |
Snap Increment
To open the Extrude Surface function:
- In the Extrude group, of the Create 3D tab, click
Extrude Surface.
Selected Geometry
The list box will list the entities currently selected for the function. |
Positive Direction
- Distance - sets the distance of the extrusion from the selected geometry in the positive direction. You can use dynamic sketch handles or data entry to set this value. The snap increment applies to the distance value when using sketch handles.
Distance Along Z-Axis |
Distance Along Normal |
Draft Angle - creates an angle along the edge of the extruded shape in the positive direction. This also applies to any internal shapes when you select more than one curve to extrude. This can be a positive or negative value.
Draft Along Z-Axis
Draft Along Normal
Other Direction
of the extrusion from the selected geometry in the negative direction.
- With Caps
- Extrudes the wireframe geometry and adds a surface to the top and bottom. All surfaces are stitched into a solid
Along Normal - the extrusion occurs parallel to the normal direction of the plane created by the selected curve.
Front View Top View
Along Z-Axis - the extrusion direction is the Z-axis regardless of how the selected curve is oriented.
Front View Top View
Quick Steps - Extrude Surface
- Open the function.
The Selected Geometry list automatically has focus. - Select the surface to be extruded.
The surface is added to the Selected Geometry list.
A preview appears showing the result using the default parameters. - Update the parameters to achieve the desired result, which is visible in the preview.
- Click OK to confirm the result.
The feature is added to the CAD Tree. - Repeat the function as necessary.
Tip: Instead of applying features to solids and surfaces more than once, go to the CAD Tree to edit the existing feature. Since all solid and surface moves, and modifications are stored in the CAD Tree, editing a feature is preferable to adding many more to achieve the desired result. This will keep file size down and help ensure files don't become slow to respond.
New.
In the Surfaces group, of the Create 3D ribbon, click the down arrow under
Planar, and select
Rectangular Plane.
The Rectangular Plane parameters display in the Data Entry Manager and the Preview appears showing the default values.
Important: The location of the Preview will vary based on the last mouse location, until the Base Point value is updated in the Data Entry Manager. However, if you click OK, the location will be placed at the Base Point, and not the preview location.
In the Data Entry Manager, leave the Width and Height values at their default values, but in the Corner Type group, select
to create a fillet, and set the value to 0.6250.
The Preview updates. -
Click OK.
The Rectangular Plane is created in the graphics area and aRectangular Plane feature is created in the CAD Tree.
Extrude Surface.
The Extrude Surface parameters display in the Data Entry Manager. -
Click the Rectangular Plane in the graphics area to add it to the Selected Geometry list.
The Rectangular Plane (Face 2-0) is added to the Selected Geometry list and the Preview is updated.
Note: The names of the geometries added to the Selected Geometry list will vary based on the amount of geometry in the file. For instance, this Rectangular Plane will always be listed as "Face ...". if it is the only geometry in the file, it will be labeled as "Face 2-0".
In the Positive Direction group, Input 0.5000 for the Distance.
Click OK to confirm.
The Extrude Surface is created in the graphics area and aExtrude Surface feature is created in the
CAD Tree.
To end this function, click Cancel.
That concludes this example.
