Project Curves
This topic will explain where to find the Project Curves function, andexplain the options found in it.This topic will also give quick steps, an example, and provide links to related topics.
The Project Curves Function
The Project Curves function projects wireframe curves ontoa selected surface or projects two curves toward each other to create geometry.
| Curves on Surfaces | Curves on Curves | |||
To open Project Curves:
Project Curves.
The function is performed using only geometry selection.
Type
Curves on Surfaces - allows you to select curves, and a surface in order to create curves against that surface which are projected in the defined direction. -
Curves on Curves - allows you to select two sets of curves, and define directions for each set, in order to create geometry at the intersection of their projection.
Select Curves to Project
Select Surface/Solid
Direction
Method
Along Z - projects the curve along the Z axis of the currently active UCS.
Pick - allows you to select a line to set as the vector of the projection direction.
Existing UCS - allows you to select an existing UCS.When selected, the curve will be projected along the Z axis.
Enter - allows you to enter a particular axis of the current UCS to use, or enter a vector manually.
Quick Steps - Curves on Surfaces
- When the function is open, the Curves on Surfaces option is selected by default, and the Select Curves to Project list automatically has focus.
Click, drag a window, or chain select the wireframe entities that you wantto project. - Click in the Select Surface/Solid list to put focus on this list.
- Select the surface or solid to project onto.
The surface, or solid is added to the list, and the preview appears showing the current result to be confirmed. - Update the direction for the curves to be projected as needed.
- Click OK to confirm the result.
- Repeat this process as needed for any other curvesto project.
- To close the function, click Cancel.
Quick Steps - Curves on Curves
- When the function is open, the Curves on Surfaces option is selected by default, select Curves on Curves.
The Select First Curves list has focus, so click, drag a window, or chain select the wireframe entities that you wantto project. - Update the direction for the first curves to be projected as needed.
- Click in the Select Second Curves list to put focus on this list.
- Click, drag a window, or chain select the wireframe entities that you wantto project..
The entities are added to the list, and the preview appears showing the current result to be confirmed. - Update the direction for the second curves to be projected as needed.
Example - Curves on Surfaces
- In the Quick Access Toolbar, click
New. - In the Primitives group, of the Create 3D tab, click
Sphere.
The preview appears.
- Leave the default values as they are and click OK.
The sphere is created.
- In the Shapes group, of the Create 2D ribbon,click
Rectangle.
The sketch handles of the sphere function disappear.The preview of the rectangle appears.
- Update the Dimension group values to Length 1.000, Width 1.000.
- Update the Base Point Z value to 1.000.
- Click OK.
- At the bottom right of the screen, click the down arrow next to the current color.
Color options appear. - Select Black.
The color options disappear.
The result of our projection will now be black. - In the Utilitiesgroup, of the Create 2D ribbon, click
Project Curves.
The rectangle preview disappears. - Hover over an entity of the rectangle, hold shift and click the entity to select the entire chain.
The entities are added to the Select Curves to Project list. - Click in the Select Surface/Solid list to give it focus.
- Highlight the sphere and click it to add it to the list.
- Click OK.
- In the document toolbar, click
to enter into selection mode. - Select the sphere.
- Delete the sphere.
Note: If the surface being projected to has two sides,meaning that it passes twice directly underneath the curves to be projected,the curved will project onto both sides just as in this example.If itpasses 3 or more times, the curves will project onto the surface as manytimes as it passes underneath.Normally only one projection is necessary,so if more are generated then the extra projections should be deletedfrom the drawing.
Example - Curves on Curves
New. - In the UCS Manager, set the Front(X/Z) UCS as the active UCS.
- In the Entity group, of the Create 2D tab, click
Arc.
- Update the Radius to 1.500.
- Click OK.
The arc is created. - Set the active UCS back to Top(X/Y).
Rectangle.
- Leave the settings to default and click OK.
The rectangle is created. - In the Utilities group, of the Create 2D ribbon,click
Project Curves. - Under Type, select Curves on Curves.
- Focus is automatically on the Select First Curves group, so select the arc.
The arc is added to the Select First Curves group. - Leave the direction to the default of Along Normal and click in the Select Second Curves group to give it focus.
The entities are added to the Select Second Curves list and the preview appears. - Leave the direction to default and click OK.
to enter into selection mode. - Select the arc and the rectangle and click delete.
