Lathe Turning Machining Strategy
The Machining Strategy page
                                                 Machining Strategy
		Machining Strategy
                                            Template
| Current Operations |
 | Available Operations | ||
| Rough Basic Finish |
                                                             | Rough Pattern Repeat Basic Finish
                                                    The Templates provide predefined groups of operations that can be applied to a feature. Select a template to populate the Current Operations list. (You can customize the DMS Defaults to define the default operations for each template.)
                                                    The Available Operations list displays all operations that exist for the selected feature type. After selecting a template, you can use the Available Operations to ad operations to the Current Operations.
                                                    Finally, you can reorder and/or remove operations from Current Operations to define all of the operations for the feature. (You can modify this list at any time, for example, when editing the feature.)
Machining Strategy Buttons
                                                     (Add Operation)
	 - adds the selected Available Operations to Current Operations. (Add Operation)
                                                     (Delete Operations)
	 - removes the selected Current Operations from the list. (Delete Operations)
                                                     (Move Up)
	 - moves the selected Current Operation up one level. (Move Up)
                                                     (Move Down)
	 - moves the selected Current Operation down one level. (Move Down)
Apply to All Features
After defining the machining strategy, click Next >> to go to The Posting Dialog Box.
The current operations that you selected are created and added to the tree on the left side of the dialog box.
 Rough
 Rough Rough / Finish
 Rough / Finish
