Lathe Ream Parameters
This topic will explain the Parameters page of the Lathe Ream operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Ream operation contains the variables needed for the feature.
Operation Parameters
- Use Cutting Conditions
 this calculates the Overall Depth and Effective Depth for this operation. Select the check box to use the values that are automatically calculated
 this calculates the Overall Depth and Effective Depth for this operation. Clear the check box to manually change the values that were automatically
 calculated. Clear the check box to manually change the values that were automatically
 calculated.
- Effective Depth - the
	 depth from theTop of Feature
	 (face of the feature), excluding the tool tip.
- Overall Depth - total depth from theTop of Part (face of the feature), including the tool tip. This value is output in the posted NC program.
Cycle Type
- Single Depth -
	 outputs a G81.
- Peck
	 - outputs a G83. The First Peck (%) parameter (Cutting
	 Conditions dialog box) allows the system to automatically
	 apply a peck cycle based on material selected and the depth of the
	 hole. For example, if the value of First Peck (%) is set to 300 percent,
	 the system outputs a G81 until the depth of the hole is 3 times the
	 diameter of the drill. When the First Peck (%) is met, the system
	 outputs the G83 cycle.
- Fast
	 Peck - outputs a G73. The First Peck (%) parameter (Cutting
	 Conditions dialog box) allows the system to automatically apply a
	 peck cycle based on material selected and the depth of the hole. For
	 example, if the value of First Peck (%) is set to 300 percent, the
	 system outputs a G81 until the depth of the hole is 3 times the diameter
	 of the drill. When the First Peck (%) is met, the system outputs the
	 G73 cycle.- Override Auto Peck  Select the check box to enter the following peck values. Select the check box to enter the following peck values. Clear the check box to use the calculated peck values. Clear the check box to use the calculated peck values.- First Peck Depth - the first peck depth in the peck cycle.
- Peck Depth - the depth of the peck.
- Number of Pecks - sets the amount of pecks that occur.
