Lathe Tap Parameters
This topic will explain the Parameters page of the Lathe Tap operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Tap operation contains the variables needed for the feature.
Operation Parameters
- Use Cutting Conditions
 this calculates the Overall Depth and Effective Depth for this operation. Select the check box to use the values that are automatically calculated
 this calculates the Overall Depth and Effective Depth for this operation. Clear the check box to manually change the values that were automatically
 calculated. Clear the check box to manually change the values that were automatically
 calculated.
- Effective Depth - the
	 depth from theTop of Feature
	 (face of the feature), excluding the tool tip.
- Overall Depth - total depth from theTop of Part (face of the feature), including the tool tip. This value is output in the posted NC program.
