This topic will explain the Parameters page of the Lathe Pattern Repeat operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page gives you the control to tweak the pattern that has been selected on the previous page. The options available to you in this page include the depth of cut, the allowance being left, the corner type, which controls whether the tool rolls over corners or not, and also allows you to trim the toolpath to the stock size and shape.
The parameters section give you the ability to adjust the distance of the pattern, the allowances used, and the number of passes to be used.
Z Distance - sets the distance in Z between the last past and any passes prior to it.
X Distance - sets the distance in X between the last past and any passes prior to it.
Z Allowance - sets the distance in Z between the last pass and the selected geometry.
X Allowance - sets the distance in X between the last pass and the selected geometry.
Number of Passes - sets the amount of passes.
Note: When the number of passes is set to 1, the Z and X Distance is not available. If only one pass is being used, it is the Z and X Allowance that sets the spacing between the cut and selected geometry.
Chip Break
The option allows you to create minute retract moves, at user specified intervals, to aid in chip breaking.
Chip Break... - With this option cleared, the toolpath will not include chip break moves.
Chip Break... -
With this option selected, the toolpath will include chip break moves that can be modified in the Chip Break dialog. Click the Chip Break button to enter the dialog.
This group allows you to determine how the intervals between retracts should be defined.
Length of cut - The retracts are determined by the amount of space between them.
Time - The retracts are determined by the amount of time between them.
Length of chip - The retracts are determined by the amount of material being removed between them.
Retract
- Retract distance - sets the length of the retract move used to break chips.
Corner Type
Round - keeps the specified tool
geometry in contact with the geometry at all times.
Sharp - allows the tool to move
off the geometry in order to line up with the next move on the following
entity. This method eliminates the rounding over of the tool.
Theoretical Point on Tool |
Rounded Corner |
Sharp Corner |
Bounds
Trim to Stock -
With this option selected, the toolpath that extends beyond
the Operation Stock will be trimmed away.
