 Leads
 Leads
Leads are an additional move added to the start and end of the cut. The Leads page handles both lead-in and lead-out moves for the following operations:
- Turning Rough
- Turning Basic Finish
- Pattern Repeat
This topic explains the lead parameters that are used for these operations types.
Lead-in
The Lead-in is an additional move prior to the initial cut into the material. The Lead-in allows you to specify how the cut is approached.
                                                         Parallel
	 - creates a lead into the material that is parallel with the
	 toolpath move it is preceding. Parallel
                                                         Perpendicular
	 - creates a lead into the material that is perpendicular to
	 the toolpath move it is preceding. Perpendicular
                                                         Horizontal
	 - creates a lead into the material that is parallel to the
	 center of rotation. Horizontal
	 center of rotation.
                                                         Vertical
	 the center rotation. Vertical
                                                         Angle
	 - creates a lead into the material that is at a 45 degree angle. Angle
                                                         Custom
	 - creates a lead into the material that is dictated by the
	 values entered in the Lead-in Z, and Lead-in X boxes. Custom
                                                            Lead-in Z - sets the distance and direction of travel, in the Z-axis, for the approach into the toolpath
                                                            Lead-in X - sets the distance and direction of travel, in the X-axis, for the approach into the toolpath
Lead-out
The Lead-out is an additional move following the last cut in the material. The Lead-out allows you to specify how the tool exits the cut.
                                                         Parallel
	 - creates a lead out of the material that is parallel with
	 the toolpath move preceding it. Parallel
                                                         Perpendicular
	 - creates a lead out of the material that is perpendicular
	 to the toolpath move preceding it. Perpendicular
                                                         Horizontal
	 - creates a lead out of the material that is parallel to the
	 center of rotation.
                                                         Vertical
	 to the center rotation. Vertical
                                                         Angle
	 - creates a lead out of the material that is at a 45 degree
	 angle. Angle
	 angle.
                                                         Custom
	 - creates a lead out of the material that is dictated by the
	 values entered in the Lead-out Z, and Lead-out X boxes. Custom
                                                            Lead-out Z - sets the distance and direction of travel, in the Z-axis, for the approach into the toolpath
                                                            Lead-out X - sets the distance and direction of travel, in the X-axis, for the approach into the toolpath
After defining the leads for the last operation in the wizard, click Compute to close the wizard and create the toolpath. If you are in a Mill Turn job, click Next> > to go to the MDI page.
