The 4th Axis Measurement (C2 Axis) Cycle
This topic will explain the 4th Axis Measurement (C2 Axis) measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures two points along the X Axis of a planar surface in order to find the angle of the surface along the XY Plane and make the necessary corrections to the rotary axis to bring the angle to zero and thus ensure a flat surface.This can also be used to check tolerance rather than to correct the rotary axis.This cycle can utilize the following geometry inputs:
- A line which is parallel to the X Axis.
- A planar surface edge which is parallel to the X Axis.
- A planar surface whose normal is parallel to the Y Axis.
To access the 4th Axis Measurement (C2 Axis) cycle:
- Click the Parameters tab.
Initial Position
- Width - determines the space between the two touch points along the X Axis.
Update Work Offset
Quick Steps - 4th Axis Measurement (C2 Axis)
- Click OK.
Example - 4th Axis Measurement (C2 Axis)
In this example we:
- Set up the UCS.
- Set up the Index System.
- Select the Probe feature.
- Select the cycle.
- Update the cycle.
- Utilize the Options page.
- Backplot the result.
Part 1) Setting up the UCS
When setting up the index system for the 4th Axis cycles, it is important to keep in mind the alignment along the X, and Y Axes.If the part is aligned with these, setting up the index system can be done by simply selecting the surface.However, if the part is not aligned properly, as in this example, it is important to create a UCS system that is aligned properly so the Index System can be created from it.
The UCS updates its alignment. - Next to X Direction, click the Reverse Direction button to update the direction of the X Axis.
The Z Axis of the UCS is updated. - Next to Z Direction, click the Reverse Direction button to update the direction of the Z Axis.
The dialog is closed.
Part 4) Selecting the Probe
Part 6) Selecting the Cycle
Note: The Pocket measure cycle measures the distance between two parallel surfaces that are both either parallel with the Y Axis, or the X Axis.In this case we measure two surfaces parallel with the Y Axis.
By default the Selected Geometry list is given focus to allow you to select geometry from the graphics area. - Select the planar surface whose normal is parallel with Y.
Since our current geometry works for a Y Single Surface cycle, that is the cycle that is currently selected for us.
Part 7) Updating the cycle
In this case, the geometry we have chosen could be interpreted as a Z Single Surface cycle.Had we chosen the planar surfaces themselves instead of the edges, the proper cycle would be selected already.However, since we did not, we will need to update the currently selected cycle.
- At the top of the Cycles section click the drop down list and select 4th Axis Measurement (C Axis) from the list.
However, notice how the end positions are tied to the initial position and one of our contact points is now off of the part.Technically we could correct this by adjusting the Width value in the Parameters section, between the two points, but we will set that value back as it was. - In the Initial Position group, update the X value by adding +0.25 to the end, and pressing Tab.
The value and the toolpath update to put the toolpath back as it was.
- In the Initial Position group, update the Y value by adding +0.25 to the end, and pressing Tab.
The Parameters section for this cycle consists of the Z Measurement Height, the Width and the Update Work Offset value.In this case we want to adjust the Z Measurement Height, and the distance between where the probe will contact the surface.The Update Work Offset value can be used as needed.
- In the Parameters section, update the Z Measurement Height value by adding +0.50 to the value and pressing Tab.
The toolpath width of the contact points is updated. - In the Parameters section, update the Width value by adding -0.25 to the value and pressing Tab.
- Click the Options tab.
- Click Close.
