The Boss (3 Point) Cycle
This topic will explain the Boss (3 Point) measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures a cylinder extruded in the Z Axis with 3 points.This cycle can utilize the following geometry inputs:
Note: The probe lifts between measurements and the touch points move in towards each other along the specified angles as this cycle is meant to measure extrusions.
To access the Boss (3 Point) cycle:
- Click the Parameters tab.
Initial Position
Z Measurement Height - determines the end point for the cycle along the Z-axis of the current Work Offset.
First Angle - defines the direction of the first touch point with the X positive direction at 0°.
Second Angle - defines the direction of the second touch point with the X positive direction at 0°.
Third Angle - defines the direction of the third touch point with the X positive direction at 0°.
Diameter - determines the width between surface contact points.
Update Work Offset
Quick Steps - Boss (3 Point)
- Click OK.
Example - Boss (3 Point)
In this example we:
- Select the Probe feature.
- Select the cycle.
- Update the cycle.
- Adjust the Parameters.
- Utilize the Options page.
- Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
The cycle can be selected with the drop down list under the Cycles section, but simply selecting the appropriate geometry will usually select the required cycle automatically. Since certain geometry could be applicable to several cycles, in some cases, the list will become much smaller. In this case however, there is only one cycle possible for the geometry we choose.
By default the Selected Geometry list is given focus to allow you to select geometry from the graphics area. - Select a cylindrical surface which has been extruded along the Z Axis, or the edge of that surface.
Part 5) Updating the cycle
In this case, the geometry we have chosen could be interpreted as a Boss (4 point) cycle.Since this is not the cycle we intended to use, we will need to update the currently selected cycle.
- At the top of the Cycles section click the drop down list and select Boss (3 point) from the list.
Note: Since our contact points are arranged in a radial pattern, adjusting the X,Y Initial Position will not work.However, we can adjust the Z Axis.
- In the Initial Position group, update the Z value to 0.375, and press Tab.
The Parameters section for this cycle consists of the Z Measurement Height, the angles on which the contact points will extend, the Diameter and the Update Work Offset value.In this case we do not really need to adjust the height at which the probe will make contact.The diameter is automatic and should not need to be adjusted, and the Update Work Offset value can be used as needed.In this part, let's just take a look at adjusting some of the angles.
- In the Parameters section, update the Third Angle value to 170 and pressing tab.
Part 8) Updating the Options section
The Options section for this cycle consists of the Radial Clearance value only.This value will allow you to set how far past the surfaces to move before dropping down to the contact depth.
- Click the Options tab.
- Click Close.
