The Boss (4 Point) Cycle
This topic will explain the Boss (4 Point) measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures a cylinder extruded in the Z Axis with 4 points.This cycle can utilize the following geometry inputs:
Note: The probe lifts between measurements and the touch points move in towards each other along the X and Y Axes as this cycle is meant to measure extrusions.
To access the Boss (4 Point) cycle:
- Click the Parameters tab.
Initial Position
Z Measurement Height - determines the end point for the cycle along the Z-axis of the current Work Offset.
- Diameter - determines the width between surface contact points.
Update Work Offset
Quick Steps - Boss (4 Point)
- Click OK.
Example - Boss (4 Point)
In this example we:
- Select the Probe feature.
- Select the cycle.
- Utilize the Options page.
- Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
The cycle can be selected with the drop down list under the Cycles section, but simply selecting the appropriate geometry will usually select the required cycle automatically. Since certain geometry could be applicable to several cycles, in some cases, the list will become much smaller. In this case however, there is only one cycle possible for the geometry we choose.
By default the Selected Geometry list is given focus to allow you to select geometry from the graphics area. - Select a cylindrical surface which has been extruded along the Z Axis, or the edge of that surface.
Note: Since our contact points are arranged in a radial pattern, adjusting the X,Y Initial Position will not work.However, we can adjust the Z Axis.
- In the Initial Position group, update the Z value to 0.375, and press Tab.
The Options section for this cycle consists of the Radial Clearance value only.This value will allow you to set how far past the surfaces to move before dropping down to the contact depth.
- Click the Options tab.
- Click Close.
