Deburr 3 Axis Example 1
This tutorial explains how to create a Deburr operation and adjust that operation to output in 3 Axis.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Deburr 3AxisExample 1.bbcd
Note: In the example fileprovided, the Tool Crib is already equipped with the necessary tools and the stock and Machine Setup are already defined.The part is simulated using the BC_3x_Mill machine.
Part 1) Add the Feature
  1. Right-click MachineSetup and click Mill Multiaxis.
  2. In the MultiaxisWizard, click Deburring.
  3. Click Next>>to go to the Posting dialogbox.
  1. The WorkOffset # is automatically set to the value defined in the MachineSetup dialog box.
    For this example, no changes are needed (more information is providedlater).
    The Tool Crib dialog appears.
Part 5) Surface paths
  3. Select the model.
Part 6) Tool axis control
  2. In the Tilting group, set the Machining type to 3 axis.
  3. Click Compute.
Part 7) Simulation
    Notice the operation is also trying to do the four vertical edges as well.
  3. To close simulation, in the menuSimulation group of the Milling Ribbon, click Exit Simulation.
Part 10) Edit the feature
  1. Notice the toolpath on the corners of the part.
  2. Right-click the feature and select Edit.
  3. Click Parameters.
  4. In the Geometry input group of the Surface paths tab, click the ellipses button next to Exclude edges.
  5. Select the corner edges.
    Repeat this on the other side of the part.
  6. Click Compute.
CutsAlong Curve
