Creating Stock Using a Solid Model
In this example you learn how to create stock using a solid model. This example will also provide links to related topics.
Creating the Stock
In this example, you learn how to create stock using a solid body in the graphics area. This creates stock that is the same as the selected solid body. The part for this example is shown first.
Part 1) Select the Stock Type
  1. By default the Stock Type is set to Rectangular.
    To create stock using a solid, under Stock Type, select Solid.
Part 2) Select the Solid Model
  1. Select the solid model in the graphics area and click Calculate Stock.
    The stock coordinate system displays at the top and center of the stock.
    Img Img
    The solid is added to the Selected Geometry list.
  2. Click Calculate Stock.
  3. Click next to go to the Machine Definition page.
In the following image, the solid model is hidden to show the stock geometry created.
Defining the Machine Setup
The Stock Wizard Tutorials
