How to Use Edit Toolpath - Delete
This example explains how to use the Delete option in the Edit Toolpath dialog box. The Delete command will allow you to select particular toolpath elements and adjust their position. The example provided will have you:
  • Setting the Command Mode
  • Selecting Toolpath Elements
  • Setting the Parameters
  • Executing the Action
  • Viewing the Animation
Example Part
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Toolpath_Editor_Delete_Example.bbcd
In the example file provided, the stock and Machine Setup are already defined for the part, and the toolpath to be adjusted has been applied.
On our example part, we need to remove stock to a uniform depth on three of our four walls. The last wall only needs the top half of the stock removed. Take a moment to notice how the last four passes cut into the model. It is the last segments of the last four passes that we will need to remove.
  1. In the Data-CAM Tree Manager, click the CAM Tree tab.
  2. In the CAM Tree, click Stock to view the assigned stock.
    Take a moment to look at the existing stock compared to the existing toolpath.
  3. Rotate the part into a side view.
    Notice the shorter depth of the wall on the left.
  1. Right-click the   Profile Rough operation of the Feature 2 Axis.
  2. Select Edit Toolpath.
The Edit Toolpath dialog gives you access to multiple Commands. For this example, we will be utilizing the Delete Command.
  1. Click the arrow on the Command list to view the list items.
  2. Select the Delete option.
Now, we need to select the toolpath segments intersecting the solid model that we want to delete, and the lead-out moves they are connected to.
  1. In the graphics area, select the toolpath elements highlighted  in the image below.
    With the toolpath segments selected, the preview is shown.
With the toolpath elements selected, we will need to set the Parameters to define how to link between the entities that still exist, since we are removing some of the toolpath. We can just leave the defaults and have the tool move to the rapid plane of the feature, but let's adjust it to stay a little lower and save some time. Be very cautions when making rapid moves occur around the part.
  1. In the Parameters group, change the Retract option to Custom.
  2. Enter -0.95 for the Rapid Plane value.
    The preview updates showing the new retract height.
Note: When the Absolute or Incremental toggle is left at the default Absolute setting, the Rapid Plane value uses the Machine Setup as zero. As such, any height below the machine setup will be a negative value.
  1. Select the Extension check box.
    The Preview updates.
  2. Enter 25 for the Extension value.
Part 6) Executing the Action
  1.  Click Execute.
Part 7) Viewing the Animation
  2. Use the Animation controls to play through the animation.
  1. Click OK.
This concludes this example.
