Tool Page
This topic serves to describe the various tool pages available, and will provide links to related topics.
The Tool Page
From this tool page, you can either, choose a different tool from the Tool Crib, go into the Tool Crib to add tools from your Tool Library, or enter tool specific data manually into the Tool Data Section of the page. This page will also assist in assigning Tool Numbers and Offsets, and Coolant options, as well as Speeds and Feeds.
Tip: It is good practice to have all the tools for the job loaded into the Tool Crib at the start of the job. If you do, the tools for the job will already be in the Tool Crib, and the system will have pulled appropriate tools for each operation from the Tool Crib.
  • Tool Crib - opens the Tool Crib for you to select a tool that you have already loaded for the job. Click to select a tool in the tools list, and click OK to assign the tool to the operation. (For Mill Turn jobs, view Mill Turn Tool Crib.
  • Assign/Edit Tool Holder - Assign Tool Holder opens the Milling Tool Holder Library to assign a tool holder to the tool. In the Tool Holder list on the right, select a tool holder/arbor, then click OK. The name of the selected tool holder appears in the Holder Label box. This holder is now the default tool holder for the tool, meaning that it is automatically assigned to the tool when you create an operation with this tool. Edit Tool Holder opens the Tool Holder Definition dialog.
The Tool Tree
The Operation Tree
Tool Data
To select a tool for the feature you can use the following option in one of two ways. Click on the images to see the work flow for each.
  • System Tool
- Select this check box to allow the software to automatically select tools from the Tool Crib that match the machining operation. In the case of end mills, you may alter the diameter and corner radius allowing the software to find the appropriate tool from the Tool Crib. In the case the appropriate tool sizes are not found, the software searches for a matching tool in the Tool Library. If a matching tool is found, it is added to the Tool Crib. If a matching tool is not found, a new tool is automatically created and added to the Tool Crib, but will not be added to the Tool Library.
- When this check box is cleared, the drop-down list becomes available allowing selection of:
  • All applicable tools currently in the Tool Crib - All tools which exist in the Tool Crib and apply to the current operation will appear at the top of the list. Select the desired tool to update which is utilized for the operation.
  • Tool Crib... - opens the Tool Crib dialog. This allows you to view the tools in the Tool Crib, as well as add tools, or modify tools already added to the Tool Crib.
  • Modify Tool... - opens the tool in the Edit Tool Parameters dialog, allowing you to manually update the tool values.
Note: Although the Machining Data group remains the same regardless of the tool selected, The available Tool Data, and the Speed and Feed parameters vary depending on the type of tool selected. Click on a tool to display the Tool Data for that particular tool. Once open, click on Machining Data and Feeds and Speeds to see the corresponding variables.
Important: Historically the coolant option found in the tool page has been a drop down which allowed you to select from Off, Flood, Mist, Air, or Oil and refers to posting blocks 673, 674, and 706 through 708. Starting in version 34 a Coolant group was added to the Machine Parameters page of the Current Settings dialog. This allowed you to use the new coolant options and refers to the new posting blocks 840-859. With the Use customized coolant options check box selected in the Current Settings, the Coolant options launches a dialog allowing you to select which coolant options are turned on for this operation. Please note that post updates may be required to utilize the newer options.
Drill
ClosedCenter Drill
  • Diameter (1) - sets the diameter of the tool.
  • Small Diameter (2) - sets the small diameter of the tool.
  • Angle (3) - sets the angle of the area between the Small Diameter (2)  and the Diameter (1).
  • Point Angle (4) - sets the angle of the tip of the Center Drill.
  • Small Diameter Length - sets the length of the Small Diameter from end of Point Angle (4) to beginning of Angle (3).
ClosedMachining Data
Machining Data
  • Override Offsets
  • Height Offset - sets the Height Offset to be used in the posted program.
  • Diameter Offset - sets the Diameter Offset to used in the posted program.
Spindle Direction
  • CW - sets the spindle direction to clockwise.
  • CCW - sets the spindle direction to counterclockwise
  • Coolant - sets the coolant on code(s) which will be output for the operation. (See the note at the top of the topic for more information on the coolant options)
ClosedFeeds and Speeds
Feeds and Speeds
  • Use System Feeds and Speeds
    Clear this check box to type feeds and speeds values in the dialog box.
  • SFM/SMM - is the surface feet/meters per minute feedrate.
  • Plunge Feed per Tooth - sets the rate of depth per tooth. The value is linked to the Plunge Feedrate.
  • Plunge Feedrate - is the downward feedrate. This value is linked to the Plunge Feed per Tooth.
  • Dwell - sets the amount of seconds to Dwell.
Note: While editing the feeds and speeds, changing one value automatically calculates any other associated values. For example, if you modify the SFM value, the Spindle RPM, Cutting Feedrate, and Plunge Feedrate are automatically calculated.
ClosedDrill
  • Point Angle (2) - sets the angle of the tip of the Drill.
  • Flute Length (3) - sets the length of the flute/cutting portion of the tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedSpiral Tap
  • Thread-  displays the thread type - size. This value is selected on the Feature page.
  • Ineffective Number of Threads (1) - sets the ineffective length for tap tools using the number of threads.
  • Thread Direction - is disabled, as it is set on the feature page.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
  • Feed per Minute - is the feedrate for the tap in feed per minute.
  • Feed per Revolution - is the total depth per revolution.
ClosedPoint Tap
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedHand Tap
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedRolling Tap
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedChamfer Tool
  • Small Diameter (2)- sets the small diameter of the tool.
  • Ineffective Length - specifies the length of extension on the small diameter that is not used for cutting.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedCounterbore
  • Diameter(1)- sets the diameter of the tool.
  • SmallDiameter (2) - sets the small diameter of the tool.
  • FluteLength (3) - sets the length of the flute/cutting portion of the tool.
  • Numberof Flutes - specifies the number of cutting flutes for the tool.
  • SmallDiameter Length - sets the length of the small diameter.
  • OverallLength - set the total length of the tool. This value must be greater than the Protrusion Length.
  • ProtrusionLength - sets the distance that the tool protrudes from the tool arbor when a tool holder is assigned to the tool.
  • ToolLabel - is the name of the tool.
  • HolderLabel - displays the name of the associated tool holder.When blank, no tool holder is associated.
  • ToolMaterial - is the tool material type of the selected tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedReamer
  • Ineffective Length (2) - sets the length of the chamfer on the tip of the tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedBoring
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
Mill
ClosedEndmill Rough
  • FluteLength (2) - sets the length of the flute/cutting portion of the tool.
  • CornerRadius - sets the size of the corner radius.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
  • Feed per Tooth - is the feedrate for feed moves in units per tooth.
  • Plunge Feed per Tooth - is the feedrate for plunge moves in units per tooth.
  • Cutting Feedrate - is the feedrate for feed moves.
  • Plunge Feedrate - is the feedrate for plunge moves.
  • Arc Slowdown % - is the amount of the feedrate to use when in arc moves. 100% is equal to the Cutting Feedrate.
ClosedEndmill Finish
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedChamfer Mill
  • Angle (2) - sets the included angle of the tool.
  • Small Diameter (3) - sets the small diameter of the tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedCorner-Round
When defining a corner rounding tool, the diameter must be greater than or equal to the small diameter plus twice the corner radius.
Diameter >= Small Diameter + (Corner Radius * 2)
If you enter values that do not fit this equation, an error message displays.
Tip: When defining a corner rounding tool, if the Diameter is greater than the current/default value, set the Diameter value first. This allows you to avoid receiving the error message. If the Diameter is less than the current/default value, set the Corner Radius first to avoid the error message.
  • CornerRadius (3) - sets the corner radius size of the tool.
  • SmallDiameter Length (4) - sets the size of the small diameter of the tool.
  • ShaftDiameter (5) - sets the diameter of the shaft.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedThread Mill
  • FluteLength - sets the cutting length of the tool.
  • ProtrusionLength (2) - sets the distance that the tool protrudes from the tool arbor when a tool holder is assigned to the tool.
  • TaperAngle (3) - sets the angle of the tool if applicable.
  • Pitch- sets the distance from one tooth to the next.
  • ThreadHeight (4) - sets the height of the threads ofthe tool.
  • ThreadAngle (5) - sets the included angle between the thread flanks.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedSingle Point Thread
  • ThreadType - With the system tool check box cleared, clicking Thread Type will allow you to select the Thread Type and Thread Size.
  • Pitch- sets the pitch of the tool.
  • ThreadHeight (3) - sets the height of the threads of the tool.
  • ThreadAngle (4) - sets the angle of the thread.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedV-Tool
  • IncludedAngle (2) - sets the angle of the tool tip.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedTapered
  • FluteLength (2) - sets the cutting length.
  • Angle(3) - sets the angle of the taper.
  • CornerRadius - sets the corner radius of the tool.
  • OverallLength - sets the overall length of the tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedT-Cutter
  • ShaftDiameter (3) -sets the diameter of the shaft.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedDove Mill
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedLollipop
  • ShaftDiameter (3) - sets the diameter of the shaft.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedDrag Knife
  • Blade Thickness (1)- sets the width of the blade.
  • Blade Offset(2) - sets the distance between the tools center of rotation and the tip of the blade.
  • Protrusion Length (2) - sets the distance that the tool protrudes from the tool arbor when a tool holder is assigned to the tool.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
Turning
ClosedLathe Rough / Finish / Boring
Show Tool Holder
Show Tool Holder
Rough Tool Finish Tool Boring Tool
Tool Data
Reference Point - allows you to choose an alignment of the reference point to the insert.
Corner
Tip
Center
Shape - sets the shape designation of the insert.   Clearance - sets the clearance designation of the insert.
Code Letter Description Diagram Nose Angle
C
80° Diamond
80°
D
55° Diamond
55°
E
75° Diamond
75°
M
86° Diamond
86°
R
Round
Full Radius
S
Square
90°
T
Triangle
60°
V
35° Diamond
35°
W
Trigon
80°
Code Letter Diagram Clearance Angle
N
A
B
C
P
11°
D
15°
E
20°
F
25°
G
30°
  • Type - sets the type designation of the insert. This does not affect toolpath or output.
  • Tool Label - adds a name to the tool, in the tool list, that allows you to easily identify the tool.
Tool Orientation
  • Insert Orientation - 1-4 sets the orientation of the tool as shown in the image. This selection influences the ability of the tool to move into locations that are restricted by adjacent geometry. The options available depend on the operation type.
Note: NOTE: The Orientation Number defines whether the cut is inside or outside of the geometry and the direction of cut and will be set for you based on the Feature Type and Region chosen in the Feature page.
  • Vertical - sets the holder to a vertical orientation.
  • Horizontal - sets the holder to a horizontal orientation.
  • Custom Angle
    - The default tool angle will be used.
    - Selecting this check box allows you to set a particular angle to the holder.
Machining Data
  • Override Offsets
  • Offset Register 1 (Diameter) - sets the register on the machine that stores the diameter offset values for the tool.
  • Offset Register 2 (Height) - sets the register on the machine that stores the height offset values for the tool (Mill Turn jobs only).
  • Suffix Code - is an alphanumeric value used for the tool numbering for certain mill-turn machines, generally those with Mazak controllers (Mill Turn jobs only).
Spindle Direction
    • CW - outputs the command for clockwise rotation of the spindle.
    • CCW - outputs the command for counter-clockwise rotation of the spindle.
  • Tool Angle Control - opens the Tool Angle Control dialog box for you to specify the rotation angles for both the milling head and lathe tool for the operation. This is used only for operations performed with a milling spindle/head and turning tool mounted to it (Mill Turn only).
Feeds and Speeds
ClosedLathe Groove / Cutoff
Groove Tool Cutoff Tool
Show Tool Holder
Show Tool Holder
Show Tool Holder
Show Tool Holder
Tool Data
Left
Center
Right
Left
Center
Right
  • Corner Radius - sets the size of the inserts corner radius.
  • Tool Width - sets the width of the insert.
  • Tool Height - sets the height of the insert.
  • Side Angle - sets the side angle of the insert.
  • Tip Angle - sets the bottom angle of the insert for the cutoff tool.
Cutoff Tool Only
Tool Orientation
This section is unavailable for the Lathe Cutoff tool.
  • Custom Angle
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
ClosedLathe Thread
Show Tool Holder
Show Tool Holder
Tool Data
The Tool Data differs slightly based on the Shape chosen.
    Corner
    Tip
  • Shape - sets the shape designation of the insert.
    Lay Down
    Top Notch
  • Tool Angle - sets the angle of the insert.
  • Tip Height - sets the tip height of the insert.
  • Orientation Number - 1-4 sets the orientation of the tool as shown in the image. This selection influences the ability of the tool to move into locations that are restricted by adjacent geometry. The options available depend on the operation type.
Note: The Orientation Number defines whether the cut is inside or outside of the geometry and the direction of cut and will be set for you based on the Feature Type and Region chosen in the Feature page.
Show Tool Holder
Show Tool Holder
Tool Data
    Corner
    Tip
    Lay Down
    Top Notch
  • Height - sets the height of the insert.
  • Width - sets the width of the insert.
Machining Data
  • Override Offsets
Spindle Direction
Feeds and Speeds
    • Pitch/Feed - is the pitch of the thread and therefore the distance per revolution.
Note: The Pitch/Feed value is controlled by adjusting the Pitch on the Parameters page.
ClosedHole Wizards
Center Drill Parameters
Drill Operation Parameters
Chamfer Drill Parameters
Chamfer Mill Patterns
Ream Parameters
Bore Parameters
Rolling Tap Parameters
Counterbore Drill Parameters
Counterbore Mill Parameters
Tap Parameters
ClosedMill Facing Feature
Facing Patterns
Closed2 Axis Feature
Profile Rough Patterns
Profile Finish Patterns
Pocket Patterns
Facing Patterns
Engrave Parameters
Plunge Rough (2 Axis) Patterns
Corner Rounding Patterns
Closed3 Axis Feature
Closed3 Axis Standard
Z Level Rough Patterns
Z Level Finish Patterns
Planar Patterns
Spiral Patterns
Radial Patterns
Plunge Rough Patterns
Closed3 Axis Pro
Advanced Rough Patterns
Flatlands Parameters
Equidistant Patterns
Pencil Parameters
Advanced Planar Patterns
Project Curves Patterns
Advanced Z Level Finish Patterns
Closed4 Axis Rotary
4 Axis Rotary Patterns
ClosedMill Thread
Mill Thread Pattern
Closed3 Axis Wireframe
3 Axis Wireframe Parameters
ClosedV-Carve
Tapered Pocketing Parameters
V-Carve Finishing Parameters
ClosedLathe End Face and Turning
Rough Patterns
Basic Finish Patterns
Pattern Repeat Patterns
ClosedLathe Groove
Groove Rough Patterns
Groove Finish Patterns
ClosedLathe Thread
Thread Parameters
ClosedLathe Cutoff
Cutoff Parameters
ClosedLathe Stock Handling
Stock Handling Parameters
