Deburr 4+1 Axis Example
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Deburr 4+1 AxisExample.bbcd
In the example file provided, the Tool Crib is already equipped with the necessary tools and the stock and Machine Setup are already defined. The part is simulated using the BC_Hermie_C20U machine.
Part 1) Add the Feature
  1. , click the CAM Tree tab Click in the CAM Tree tab to access the Mill Job.
    The Tool Crib dialog appears.
Part 5) Surface paths
  3. Select the model.
Part 6) Tool axis control
  3. Click Compute.
Part 7) Editing the feature
  5. Select the edge along the outer diameter of the part as seen in the image below.
  6. Repeat this for the remaining edges.
  7. Click OK.
  8. Click Compute.
Part 8) Simulation
  3. To close simulation, in the menuSimulation group of the Milling Ribbon, click Exit Simulation.
Part 9) Edit the feature
  5. Click Compute.
Part 10) Simulation
Cuts Along Curve
