Continuous Sketch
This topic will explain the Continuous Sketch function, will explain where to find the function, and explain the options found in it. This topic will also give a brief description of the Snap Increment function, explain creation with quick steps, and provide links to related topics.
The Continuous Sketch Function
The Continuous Sketch function is used to create a continuous chain of lines, arcs, or a combination of the two.
Snap Increment
To open Continuous Sketch:
Continuous Sketch.
- Line Tolerance - sets the distance that you can move the pointer away from an entity before it is deformed into an arc.
Point List
This list box will show the entities currently selected for the function. |
Quick Steps - Continuous Sketch
- To perform the function, you click in the graphics area to define the start point.
- Move your mouse and notice the preview of a line being created.
Click in the graphics area again to set the second point. - Move your mouse to the third position.
Click in the graphics area again to set the third position.
Note: Notice a line, or arc can be created depending on the position of your mouse on the third click. You can even make your second and third position clicks the same, to create a line ending at that point.
- Move your mouse again to being the process again.
- Click OK to end the chain of lines/arcs.
- Click Cancel to close the function.
