Skin Surface
This topic will explain the Skin Surface function, and the options found in it. This topic will also describe where to find the function, provide quick steps and an example on how to use it, and provide links to related topics.
The Skin Surface Function
The Skin function is used to create a surface using two or more wireframe chains as cross sections and two or more wireframe chains as rails. To create the surface, you chain select the cross sections, which share the same general direction, and then chain select the rails last, which also share the same general direction.
Tip: Just like the Cross Section surface creation function, this Skin surface creation function can use many cross sections to set the shape of the surface. The Skin function, however, also has the added benefit of rail curves to guide surface creation even further.
To open Skin Surface:
  • In the Advanced Surfacesgroup, of the Create 3D tab, click Skin Surface.
Cross Section Curves
(Reverse Direction) - Reverses the direction of the highlighted item.
The list box will list the entities currently selected for the function.
Rail Curves
Quick Steps - Skin Surface
When creating Skin Surface, you chain select each of the cross sections and rails. Each chain can be one or more entities. Select the cross sections so they share a direction and select the rails so they share a direction.
  1. Open the function.
    The Picking Manager appears.
  2. Chain select the first Cross Section Curve.
    The chain is added to the Cross Section Curves list.
Tip: To chain select an entire chain, use the Auto-Chaining options and click near the end of the last entity to set the start and end of the chain in one click. To select a portion of a chain, turn off Auto-Chaining and use Manual Chaining to click near the end of the first chain entity to set the start of the chain, then click near the end of the last entity to set the end of the chain. Click End Chain to finish the chain.
  1. Chain select the second Cross Section Curve in the same general direction as the first.
  2. Repeat this process for the two rails.
    The Preview displays once a surface can be created.
  3. To finalize the surface, click OK in the Data Entry Manager.
    You can repeat this process for any other surfaces.
  4. To close the function, click Cancel.
  1. Select Skin Surface Example, and click Open.
    The file opens.
  2. In the Advanced Surfacesgroup, of the Create 3D tab, click Skin Surface.
    The Picking Manager appears, the Skin Surface parameters display in the Data Entry Manager and the Cross Section Curves list is given focus to accept selection of chains.
  3. The first step is to select a chain to assign as a Cross Section Curve.
    Turn off Auto-Chaining, select the Multi-Entity mode, and highlight the entity as seen in the image below.
  4. Since this is a single entity, one click gives us the intended start and end of the chain automatically.
Tip: While selecting the geometry for a cross section, you can click the start arrow to change the direction of that cross section, or use the Reverse button after highlighting that chain in the Selected Geometry list of the Cross Section Surface parameters  in the Data Entry Manager. It is important that all of the cross sections share the same direction.
  1. Hover over the end of the next Cross Section, as seen in the image below.
  2. Click the entity.
  3. In the Picking Manager, click End Chain.
    The chains are added to the Cross Section Curves list.
  1. In the Data Entry Manager, click in the Rail Curves list to give it focus.
  2. In the Picking Manager, switch to Manual Chaining and hover over the end of the first Rail, as seen in the image below.
  3. Click the entity to set the start and end of the chain.
  4. Click End Chain.
    The chain is added to the Rail Curves list.
  5. The second rail is the first of our chains that is comprised of several entities. Hover over the end of the first entity of the second Rail, as seen in the image below.
  6. Click the entity to set the start of the chain.
  7. Highlight the end of the last entity of the chain, as seen in the image below.
  8. Click to set the end of the chain.
  9. In the Picking Manager, click End Chain.
    Now, with enough Cross Sections Curves and Rail Curves to create a surface, the Preview appears.
  10. Click OK to finalize the Skin.
    The surface is created in the graphics area  and a Skin feature is created in the CAD Tree.
  11. To end the function, click Cancel.
The CAD Overview
