4 Edge Surface
This topic will explain the 4 Edge Surface function, and the options found in it. This topic will also describe where to find the function, provide quick steps and an example on how to use it, and provide links to related topics.
The 4 Edge Surface Function
The 4 Edge function creates a 3-dimensional surface using 4 connected edge curves. To perform the function, you chain select the four geometry curves in the Workspace one at a time, and then press the Spacebar to confirm the selections.
To open 4 Edge Surface:
In the Modify group, of the Create 3D tab, click
4 Edge Surface.
Selected Geometry
This list box will show the entities currently selected for the function. |
Quick Steps - 4 Edge Surface
When creating 4 Edge Surface, you chain select each of the four surfaceedges.Each chain can be one or more entities. The selection order determines the results, so the chains should all share the same general direction, such as clockwise.
- Open the function.
- Chain select the remaining chains.
Once surface creation is possible, a preview will appear. - Use the controls next to the Selected Geometry list to adjust the direction of chains, the chains order in the list, and which chains are in the list.
- Click OK to create the surface.
This example will demonstrate how to use the 4 Edge function.
In the quick access toolbar, click
Open.
Select 4 edge surface example.bbcd,and click Open.
The file opens.
4 Edge Surface.
The 4 Edge Surface parameters display in the Data Entry Manager and the Picking Manager appears. -
Highlight the end of the first entity, of the first chain, as seen in the image below.
Note: In this example, each chain is a single entity. If these chains were multiple entities; With Manual Chaining, click the end of the first entity of the first chain to set the start point and direction of the chain. Then click the end of the last entity of the first chain to set the end of the chain. Then repeat for the subsequent chains.
Click the entity to set the start and end of the chain.
In the Picking Manager select End Chain.
Tip: While selecting the geometry for a 4 Edge, you can click the start arrow to change the direction of that cross section, or use the Reverse button after highlighting that chain in the Selected Geometry list of the 4 Edge Surface parameters in the Data Entry Manager.It is important that all of the chains share the same direction.
Hover over the end of the next chain, as seen in the image below.
Click the entity to set the start and end of the second chain.
The chain is added to the Selected Geometry list. -
Hover over the end of the third chain, as seen in the image below.
Click the entity to set the start of the third chain.
Hover over the end of the last chain, as seen in the image below.
Click the entity to set the start and end of the last chain.
The chain is added to the Selected Geometry list and the preview appears. -
Click OK to finalize the 4 Edge.
The surface is created and a4 Edge feature is created in the
CAD Tree.
