Lathe Groove Machining Strategy
The Machining Strategy page
Machining Strategy
Template
Rough Rough / Finish
Current Operations |
Available Operations |
Groove Rough Groove Finish |
The Templates provide predefined groups of operations that can be applied to a feature. Select a template to populate the Current Operations list. (You can customize the DMS Defaults to define the default operations for each template.)
The Available Operations list displays all operations that exist for the selected feature type. After selecting a template, you can use the Available Operations to ad operations to the Current Operations.
Finally, you can reorder and/or remove operations from Current Operations to define all of the operations for the feature. (You can modify this list at any time, for example, when editing the feature.)
Machining Strategy Buttons
- (Add Operation) - adds the selected Available Operations to Current Operations.
- (Delete Operations) - removes the selected Current Operations from the list.
- (Move Up) - moves the selected Current Operation up one level.
- (Move Down) - moves the selected Current Operation down one level.
Apply to All Features
After defining the machining strategy, click Next >> to go to The Posting Dialog Box.
The current operations that you selected are created and added to the tree on the left side of the dialog box.
