This topic will explain the Parameters page of the Lathe Basic Finish operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page gives you the control to tweak the pattern that has been selected on the previous page. The options available to you in this page include the allowance being left, the corner type, which controls whether the tool rolls over corners or not, and also allows you to trim the toolpath to the stock size and shape.
The parameters section give you control over the allowances, if any, that are left on the selected geometry
Finish Allowance - will allow you to leave material on the workpiece to be handled by another finishing pass. Setting values for the Finish Allowance will leave the last pass of this operation offset from the selected geometry by the amount entered in the available Z and X boxes.
No
Finish Allowance
Chip Break
The option allows you to create minute retract moves, at user specified intervals, to aid in chip breaking.
Chip Break... - With this option cleared, the toolpath will not include chip break moves.
Chip Break... -  With this option selected, the toolpath will include chip break moves that can be modified in the Chip Break dialog. Click the Chip Break button to enter the dialog.
Chip Break... Chip Break...
This group allows you to determine how the intervals between retracts should be defined.
  • Length of cut - The retracts are determined by the amount of space between them.
  • Time - The retracts are determined by the amount of time between them.
  • Length of chip - The retracts are determined by the amount of material being removed between them.
Retract
  • Retract distance - sets the length of the retract move used to break chips.
Corner Type
Round - keeps the specified tool geometry in contact with the geometry at all times.
Sharp - allows the tool to move off the geometry in order to line up with the next move on the following entity. This method eliminates the rounding over of the tool.
Theoretical Point on Tool
Rounded Corner
Sharp Corner
Bounds
Trim to Stock -  With this option selected, the toolpath that extends beyond the Operation Stock will be trimmed away.
