Continuous Sketch
This topic will explain the Continuous Sketch function, will explain where to find the function, and explain the options found in it. This topic will also give a brief description of the Snap Increment function, explain creation with quick steps, and provide links to related topics.
The Continuous Sketch Function
The Continuous Sketch function is used to create a continuous chain of lines, arcs, or a combination of the two.
Snap Increment
To open Continuous Sketch:
Continuous Sketch.
- Line Tolerance - sets the distance that you can move the pointer away from an entity before it is deformed into an arc.
Point List
Quick Steps - Continuous Sketch
- To perform the function, you click in the graphics area to define the start point.
- Move your mouse and notice the preview of a line being created.
Click in the graphics area again to set the second point.
- Move your mouse to the third position.
Click in the graphics area again to set the third position.
Note: Notice a line, or arc can be created depending on the position of your mouse on the third click. You can even make your second and third position clicks the same, to create a line ending at that point.
- Move your mouse again to being the process again.
- Click OK to end the chain of lines/arcs.
- Click Cancel to close the function.
